Clutch problems
anyone notice a slight grinding sound when downshifting into second or going from first to second gear. on my 04 i notice a slight grinding sound when ever i do this.
I don't think that's your clutch I think it's your second gear synchros. You should be under warranty. I would take it to honda and let them check the tranny fluid for particulate. I don't know how the o4 tranny is but the 2nd gear synchros are a weak spot in the tranny design of the 00-03 because of the way it engages and disengages
fltsfshr
fltsfshr
My '02 does this sometimes, particularly when the tranny is cold. It also only happens on the 1-->2 shift. Try shifting into 2nd just a split moment slower, and see if that helps. On mine, if I shift from 1-->2 quickly and the tranny is cold, I risk grinding. If I shift slowly and gently, I won't grind, but I sometimes feel resistance for about a second before the stick slides in easily. This all stops once the tranny is fully warmed up.
Great,
Honda "Fixed" this for the MY04 - or not.
You are not the 1st MY04 owner to have this happen, and it is a problem on pre 04 models.
Sad to see Honda supposedly fix it, then not.
Good luck at the stealerships, they deny too many legitimate claims.
I have a My04 too and notice the 2nd gear synchros need to be warmed up before you start jamming on them. For the first 1/2 to 1 mile drive your car like a baby and do real slow shifts. After that, you're tranny should work fine unless it's real cold out. I try to go through all the gears once or twice gently before I consider the car warmed up. Have fun. Engine temp alone won't let you know that your car is warmed up.
wow i have a MY03 and i never had this grinding problem (knock on wood). i have ~5k miles now.
i guess it depends on how well the tranny was put together in japan(if the guy was drunk from sake or not j/k ).
