Which coilover to get?
Old Aug 27, 2006 | 04:30 PM
gomarlins3's Avatar
On the less expensive side, I like my Ground Control's with Koni Yellows.
Old Aug 28, 2006 | 09:37 AM
efthimios's Avatar
Originally Posted by s2ka,Aug 24 2006, 10:57 PM
Bistein PSS9, good ride and better handling than stock. The range of adjustment allows you to go from nearly stock to very firm for the track. The guys at Eibach shock dyno'd them and were impressed. Great quality at a decent price. See my sig for more info on my install.
I'm going to have to 2nd that, I installed mine a couple weeks ago and they're amazing for the price
Old Aug 28, 2006 | 10:37 AM
afwfjustin's Avatar
Bilstein is good.
Old Aug 28, 2006 | 04:51 PM
AJ PwR's Avatar
Originally Posted by S2K_Mike,Aug 25 2006, 03:56 PM
How is the handling with the T1R's compared to stock? Better/worse/same?
I can get the KW V2's for about the same price as the T1R's...which would you guys choose?
When you are at the softest setting, the ride will be a bit sofetr than stock. ONce you dial it up, it improves handling a lot.
Old Aug 28, 2006 | 07:08 PM
Harpoon's Avatar
Originally Posted by Emil St-Hilaire,Aug 25 2006, 04:11 PM
Aragosta.
Are you running the Aragosta set Emil? Are you referring to the ASM one?
Old Aug 28, 2006 | 07:25 PM
Costas's Avatar
I'm in the same situation. I was slammed on buddyclub coilovers and although the car felt like it handled good, it actually had pretty bad understeer. I'm back on stock suspension right now and I prefer it a whole lot more. Of course it's alot more tail happy but I've learned to control it.
The only thing that I hate now is the 4x4 look, I was considering just getting springs to lower the car, but I was curious to know if springs would hurt the handling more so than coilovers would (under $1500).
Old Aug 29, 2006 | 05:51 AM
Nhan's Avatar
I also just got this installed about a month back. Loving it so far.. Same price range as tein flex & t1R-bmax, so choose wisely
Old Aug 29, 2006 | 09:33 AM
S2K_Mike's Avatar
Ok I am now leaning towards the T1R bmax. A&J now has a deal on them right now...decision decisions...
Old Aug 29, 2006 | 11:17 AM
Ek9's Avatar
Ek9
Banned
I don't understand why you'd spend bank on a set of coilover's you'll set once and that'll probably never see a track when you could spend under $1000 for GC coilovers and Koni shocks which are better shocks then 95% of the shocks coming out of Japan.
The B-Max-R's are very pretty and have decent specs but, why spend $500 more for features you'll NEVER use? Do you really need rebound adjustment?
Old Aug 29, 2006 | 11:43 AM
S2K_Mike's Avatar
[QUOTE=Ek9,Aug 29 2006, 12:17 PM]I don't understand why you'd spend bank on a set of coilover's you'll set once and that'll probably never see a track when you could spend under $1000 for GC coilovers and Koni shocks which are better shocks then 95% of the shocks coming out of Japan.
