Coilovers
Old Aug 24, 2001 | 04:04 PM
redleader's Avatar
Default Coilovers
What is the difference between a "coilover" and a regular shock/spring assembly? Don't all springs "coil over" the shock assembly (in a physical sense)? I'm having trouble understanding the terminology here.
Old Aug 26, 2001 | 10:21 AM
newguy's Avatar
On the S2000 all suspenison is a shock inside a coil spring, but there are many other ways for a car to be sprung. Leaf springs, coil springs seperate from the shocks and torsion bar suspension are a few other types, but I doubt you'd see them on cars like the S2000.
Old Aug 26, 2001 | 10:41 AM
The Reverend's Avatar
What newguy said is correct. Also, many people use the term "coilover" in reference to threaded-body coil-over setups. In this case, the shock body has threads and the spring perch is screwed on so it can be adjusted up or down on those threads to change your ride height. This can either be done with a shock/spring combo that was designed form the get-go to work like this like a Tein coilover setup, or by adding a threaded sleeve to your existing shock - as the comptech kit does.
Old Aug 26, 2001 | 10:05 PM
redleader's Avatar
so I guess people use that term, "coilover" pretty loosely then huh? Sometime I ask people what kind of shock/spring set up they have and they say the have such and such "coilovers". I'm thinking, well that doesn't tell me much because all shock/spring assemblies on the s2000 are "coilovers" (in the physical sense).
Old Aug 27, 2001 | 01:25 AM
4373's Avatar
[QUOTE]Originally posted by The Reverend
[B]What newguy said is correct.
Old Nov 6, 2012 | 02:32 PM
Bigdaddydave22's Avatar
so i have a question for u awesome fellow s2k guys
i wrecked my front drivers side finder and bumper
im going to need all kinds of parts (if u have anything pm me)
so any how im looking at some function and form type 2 coilovers
im all road haven't made the time to do track work
http://stlouis.craigslist.org/pts/3355887847.html
factory web site
http://www.functionnform.com/Functio...2009_p_44.html
thank you for your time
Old Nov 6, 2012 | 06:43 PM
RedCelica's Avatar
Please do not bump 11 year old threads. Thank you. We also have a forum dedicated to suspension and brakes...use it: https://www.s2ki.com/s2000/forum/249-
1wides2k
Oct 2, 2011 10:13 AM
gotap1
Nov 12, 2010 06:30 AM
masterthl
Jun 5, 2008 12:09 PM
Leg3nda12y S
Aug 10, 2006 09:28 PM
daniel_h23_2000
Dec 1, 2003 11:41 AM
