Coilovers choice
Old Mar 17, 2007 | 08:29 AM
l-teg's Avatar
Default Coilovers choice
Ok I know this has been reviewed over and over and I read the posts on the quality as well. Overall everyone seems to say both are good and happy with both. I have had shocks and spring combos (neuspeed/Koni) I have had coilovers (skunk/koni) on my other cars & also driven an S with Zeals.
I just want to know if the T1R are worth the extra $600 over the megan's?
I am using my car mostly for city driving with the occasional autocross so should I spend the extra cash or use it for something else like swaybars?
I don't need a crazy setup like the Zeals plus don't want to spend the $4k on them. All I want is something as good if not a bit better then the factory set up with getting the look of a lower car.
also for the price of the T1R i can get a few other brands like Tein,H&R would those be better?
I just don't want to spend the cash twice but don't want to spend more then is needed as well as i can only drive the car 6months out of the year!
Thanks
Old Mar 17, 2007 | 09:11 AM
vboy720's Avatar
hmmmm, i would recommend the t1r bmax out of the 2. t1r really does there research into there products. everyone says the t1r coilovers, and even there exhaust are great products. somethin else i would consider in the same price range of the t1r is bilstein pss9's or kw variant 2. the bilstein pss9's might suite u a little better, more city drivability. the t1r and variant 2 will be good to, but better on the track.
Old Mar 17, 2007 | 09:57 AM
jah's Avatar
jah
spend it on something else.
functional oem suspension here, considering only occasional autox use.
Old Mar 17, 2007 | 10:05 AM
kentarou's Avatar
i am getting the Spoon fix type dampers and the progressive springs.....
should be here in a week or two.....
only heard good things about them, so......
will post some updates if i have time...
BulldogS2's Avatar
between the 2...........megan
Old Mar 17, 2007 | 12:59 PM
Popeye's Avatar
KW v2 anything else is a waste of $$$
Old Mar 19, 2007 | 10:33 PM
Aze85's Avatar
T1R by FAR!
the bmax coilovers are on of the best, if not the best, coilovers for our car that is not an external reservoir setup. it has a much larger tube diameter than other shocks in its "class". that means more fluid displacement with less movement. very good coilover. i love mine
Fastfour
Jan 5, 2010 08:52 AM
S2G-Unit
Mar 20, 2007 05:23 PM
Touge Freak
Nov 7, 2006 08:53 AM
FormerH22a4
Mar 22, 2006 06:32 PM
Tel1sps
Oct 19, 2005 06:02 AM
