cold start CLUNK?
Old May 6, 2002 | 12:06 AM
minboost's Avatar
Default cold start CLUNK?
Every so often I will start my car in the morning and as I go into gear (reverse) I hear a very loud CLUNK. I did a search for the clunk but all I came up with is the differential. But my car isn't even moving when I get the clunk and it only happens once and not even all the time.
What could it be and should I be fixing something?
My car is a stock 02.
Old May 6, 2002 | 01:51 AM
Optional G's Avatar
Do you leave the clutch up or down while warming the car up?
Try this:
1. After you warm up your car, press down the clutch
2. Keep it down and wait for 15 seconds
3. Still keeping the clutch down, shift into reverse
Let me know if this helps. I was rading this (regarding "SIDE NOTE ON GETTING INTO REVERSE"):
http://www.waycoolinc.com/z3/essentials/fi...oe/shifting.htm
Old May 6, 2002 | 04:20 AM
cthree's Avatar
Administrator
The transmission is cold and so is the fluid. I'm not surprised. I'm sure it goes away after a couple miles right? I'd say it's normal but then I haven't heard it so can't be sure.
Old May 6, 2002 | 04:34 AM
TechBoy's Avatar
Does the clunk only occur after you use the trunk? I find that my spring mechanism pops about 10-20 seconds after I close the trunk... about the same time that I am normally putting the car into gear.
Old May 6, 2002 | 04:38 AM
4Cars1Teenager's Avatar
I KNOW I KNOW I KNOW what it is!!!
maybe
do you use the hand brake when the car is parked when this happens? It used to happen with my car, the brake would stick and when the car moved it would come un-stuck, effectivly clunking. I think it happend when i washed the car, might be cause it froze on there, but i stopped using the brake when it's in the garage now, no more clunk.
Old May 6, 2002 | 07:09 AM
honda606's Avatar
Change out your tranny fluid with something high quality like Redline and this problem should cease to exist.
Old May 6, 2002 | 10:13 AM
Jenner's Avatar
I agree with 4Cars1Teenager . I have the same "clunk" and it is because of the parking brake and the rear pads sticking if I don't drive the car for a few days and/or it rains or I wash it. Which means it happens to me often because I don't drive it in the rain but it splaters up on the rotors even with my car cover.
Old May 6, 2002 | 01:10 PM
tajarif's Avatar
It is due to the Hand Brake like previously stated. The first time it happened to me I absolutely freaked out
Old May 6, 2002 | 06:00 PM
JsnS2k's Avatar
Your letting your car warm up for a fair amount of time right?
Old May 6, 2002 | 09:10 PM
Utah S2K's Avatar
Holy Jesus these threads scare me!!!!!!!! (I can say "Holly" and "Jesus" as I am in Utah .
The clunk is a brake pad drop......no big deal!!!! Most often in reverse....more often after a car wash !
Don't wory be happy......
Utah
