Color matching brake caliper paint to Spoon Blue
Hello,
Has anyone correctly matched brake caliper paint to the Spoon blue calipers? May I ask which brand of brake caliper paint kits would do the trick? I have looked online at G2, Folia Tec, and Dupli-color brake kits in blue and they all seem to be off or slightly off in color. I have a set of Spoon mono block calipers but am trying to color match the oem rear calipers to the Spoon fronts.
I did a search on this forum and have basically come up empty handed. Any help is appreciated.
Thanks,
Will
Thanks,
Will
Originally Posted by Hockey,Jun 1 2006, 01:20 PM
Contact G2 directly. They did a custom paint match for us last year. Didn't even charge us extra. They'll need a color sample.
-Hockey
-Hockey
Originally Posted by gosixers215,Jun 1 2006, 10:25 AM
Would a picture or image suffice? Or would they need an actual paint sample?
Originally Posted by Hockey,Jun 1 2006, 09:27 AM
We sent them an actual sample, but they might be able to work it out with an accurate pic. Not sure.
Whom did you contact over there? Did you send them an actual Spoon caliper?
Thanks,
Will
Originally Posted by willfong,Jun 1 2006, 07:03 PM
Would there be a color code on your paint kit from G2?
Thanks,
Will
Thanks,
Will
-Hockey
Update...
G2 has created a good match to the Spoon anodized blue which I received a couple of days ago. I am including a pic of this below. Due to the custom matching and custom mixing of paint, they had to make a quart of this custom color. The match is nearly perfect but not 100% as the Spoon calipers are anodized blue. So there is just a little depth and metallic difference in the blue. But overall the guys at G2 believe this is the closet match possible.
Cheers!
Will
edit: please do not post commercial content - S2000GT
Cheers!
Will
