comming up on 100,000 miles
Old Nov 9, 2010 | 08:41 AM
ltgrazer65's Avatar
Default comming up on 100,000 miles
Hey, comming up on 100,000 miles on MY04 and loved every mile. Of course I changed the oil but what are some other things that need to be repaired at this time.
Old Nov 9, 2010 | 08:45 AM
lman's Avatar
valve adjustment, spark plugs replace, maybe a leak down and compression test. regrease the shifter, transmission oil, diff oil, air filter.
Old Nov 9, 2010 | 10:12 AM
Supra-holic's Avatar
Congratz on the AP2 in the 100s.
Replace clutch fluid, look under the dash for leaks off the master
Replace brake fluid
Inspect Serp. Belt (should be OK I have 150K on mine)
Inspect PCV
Air cabin filter
Inspect air intake filter
Alignment if needed
Check tire pressure on spare
Old Nov 9, 2010 | 10:52 AM
whitebrad25's Avatar
you must have a special s2000
chain tensioner...no serpentine belt in our cars. and that should be good as long as the car is...the only occasional problem is the common TCT
Old Nov 9, 2010 | 11:15 AM
Yup its a magical belt that runs my AC and alternator.
Old Nov 10, 2010 | 06:20 AM
CosmosMpower's Avatar
LOL
I think the coolant is first due for a chance around 100K too if your original radiator end tank hasn't cracked and been replaced. I think everyone else just about covered it.
Might want to crawl under and see if you can find any cracked/worn bushings as well in the control arms etc.
Old Nov 10, 2010 | 08:06 AM
suzuka-blue-s2k's Avatar
Replace your cabin filter.
Old Nov 10, 2010 | 09:13 AM
stauren1203's Avatar
sphincter valve. just kidding.
Old Nov 10, 2010 | 10:21 AM
RedCelica's Avatar
HID headlight fluid
blinker fluid
Old Nov 10, 2010 | 01:00 PM
D-Clem's Avatar
you may want to recheck your mechanical abilities, you are wrong, obviously. i hope you were kidding.
but to the op- these guys pretty much have it covered with the first few posts. good luck!
