Comptech intake question...
Old Jan 30, 2005 | 12:31 PM
TunedS2000's Avatar
Default Comptech intake question...
Inside the air box my filter rubs the bottom/side of the box which in turns causes the filter to not hold its cone shape. Everytime I take my filter out to clean it, it looks like it has a dent in it on the top side. I have seen some filter/intake pics here and it seems like their comptech filter is longer/thinner and does not rub their intake box. What does you guys suggest? Anyone els here have this problem (if it really is a problem)? Anyone here with a comptech intake running a K&N filter (or other filter)? Let me know what you think... Thanks
Old Jan 30, 2005 | 12:48 PM
fin man's Avatar
I've got the Comptech CAI but I use the foam filter. Maybe you should try loosening the clamps and try changing the angle of the filter in the box.
http://img.photobucket.com/albums/v364/fin...0X600arrows.jpg
Old Jan 30, 2005 | 12:51 PM
TunedS2000's Avatar
I also am using the Comptech foam filter. I was mentioning the K&N because I was curious if anyone had switched to it. I have tried adjusting what you said but I will give it another shot. Anyone els with some ideas?
Old Jan 30, 2005 | 01:00 PM
RARE M5's Avatar
Interesting... I had a comptech CAI on my 03. I never had any problem with it. I noticed some rattling on spirited drives but that was fixed later by re-adjusting and tighten the CAI. You may want to experiment by re-aligning the CAI. Good luck.
Old Jan 30, 2005 | 07:36 PM
TunedS2000's Avatar
bump
Old Jan 30, 2005 | 08:03 PM
Matt The Bagel's Avatar
Unhappy
I just got mine installed on a 03. The screws seem to be popping off. Have you had this problem? Also it is rubbing with the hood and leaving a white mark on the carbon fiber.
Old Jan 30, 2005 | 08:26 PM
FraudulentNeon's Avatar
Banned
Aren't foam filters known for their poor filtering abilities? Not really sure, just curious.
Old Jan 30, 2005 | 09:11 PM
TunedS2000's Avatar
I have taken the filter off and not seen any dirt on the inside of the filter or the pipe so I guess the foam filter fliters the air just fine. I dont have the problems with the screws. Any other ideas on how to fix my problem?
Old Jan 30, 2005 | 09:45 PM
TwistedS2k's Avatar
no problem here as you can see
Old Oct 14, 2006 | 06:42 AM
Chris S's Avatar
Considering that dirt bikes use foam filters, I'd guess they're pretty same for an S2000!
