Correct Jack Stand Spots?
Old Nov 11, 2014 | 12:13 PM
Aubs's Avatar
Default Correct Jack Stand Spots?
So I am super new to working on cars. I am not the least experienced person in the world for working on machines, as I had a 2007 GSXR a while back (before some guy tried to kill me on it) and did much work on that. But I never had to put it on jack stands of course! I know there's an official thread regarding jack stand points and all but I just wanted to make sure I've got it 100% correct because sticking my head under a 2000 pound object is a little scary! So, do I have them in the right spots? Please go easy on me if I do not! Thanks!!!
Old Nov 11, 2014 | 12:25 PM
Ryuu's Avatar
bout 4 to 6 inches from the front and 4 to 6 from the back between the wheels, you should notice built up steel... there is where.. you place the stands...
can't see the photos
Old Nov 11, 2014 | 01:12 PM
Aubs's Avatar
http://postimg.org/gallery/2z70cjpyi/0800390a/
Can you see these? Just to be sure!
Old Nov 11, 2014 | 01:22 PM
s2000ellier's Avatar
if i were you i'd put them on the pinch weld where there is a reinforced section
Old Nov 11, 2014 | 01:25 PM
2Kaputnik's Avatar
In your photos it is clear that you are NOT using the correct jack points.
In one of your photos you can see the correct pinch weld where the jack should be. You can also clearly see frame rail damage from using inappropriate jack points.
Use your search engine. This has been discussed ad nauseum in many threads of S2Ki. Read the posts and use only the factory approved jack points. There are six - two on each side, and one at each end for lifting with the floor jack. None of these are in use in your photos.
Old Nov 11, 2014 | 02:24 PM
noodels's Avatar
Would do a search as suggested
and quickly do avoid any more chassis damage
Old Nov 11, 2014 | 04:06 PM
skaius's Avatar
jack point is outer edge.. hurry and stop the damange to the frame!
goldenfri
Hard at Work
2015
Dec 13, 2018 12:50 PM
rugsr
Dec 22, 2007 06:16 PM
e3opian
Hard at Work
2029
Dec 5, 2007 11:22 AM
S~Factor
24
Feb 5, 2007 10:46 AM
martha
Jan 14, 2007 04:19 PM
