CR suspension in MY00
I have a MY00. I am looking at suspension for it. I started thinking after reading about how well the "stock" CR suspension performed, what if I put CR shocks and front and rear sway bars and probably the streering rack stiffener on my MY00.
Compaired to the cost of some of the coilover set-ups it is fairly cheap. You could pick up all of the parts from Hardtop Guy for about $1500.
What do you guys think?
mlc
Edit: If there is a CR owner out there. Have you driven both a CR and a non CR and how much of a change in ride should I expect?
mlc
Originally Posted by mlc,May 13 2008, 11:50 AM
I just figured if I can get OEM parts that perform as well if not better them after market stuff, why not.
pss9s are worth looking at; they have similar spring rates and could be a bit cheaper. the performance is probably comparable, but you may prefer a dropped look.
also, have there been any issues with getting a larger-than-normal gap when installing CR springs, or am i remembering wrong/was it a poor install?
