Crankshaft pulley?
Old Jul 27, 2005 | 12:31 PM
Ks320's Avatar
Default Crankshaft pulley?
I'm sure this has been discussed before (but at least not recently).
Has anyone tried using a light crankshaft pulley for their S? Or even the whole set (including alternator, power steering, A/C)?
Was there an improvement?
Or they don't even exist at all ...
Thanks.
Old Jul 27, 2005 | 02:14 PM
DaveOnLI's Avatar
Rick's used to offer lightweight aluminum pulley sets. I think there was a lack of interest and are no longer offered.
Billman250 has them on his car, he can comment to their performance.
Old Jul 27, 2005 | 02:18 PM
Incubus's Avatar
My advice is: Unless you race and plan to rebuild your engine, then avoid the crankshaft pulley.
Honda has a harmonic balancer on the stock pulley. Aftermarket ones do NOT. I'd just look somewhere else for extra power.
Old Jul 27, 2005 | 04:02 PM
kane.s2k's Avatar
The light weight crank pulley will blow your engine eventually
Old Jul 27, 2005 | 04:03 PM
brent_strong's Avatar
Pretty much. I'd bet the wear on the main bearings for Cyl 1 and 2 would show notably increased wear after 10k+ miles without a damper.
Old Jul 27, 2005 | 04:17 PM
Ks320's Avatar
Thanks for your replies ...
I never knew about the harmonic balancers when I had it on my old car until much later after I've installed it, but then I never had the car long enough to notice a durability issue (only had the car for around 15Kmiles but liked the improvement in response, though dyno showed a mere 3hp of gain on that).
In any case, thanks!
Old Jul 27, 2005 | 04:29 PM
Yeah, I ran one on my last car and it gave a notable power increase (dropped something like 8-10lbs off the pulley weight along with a good amount of underdrive), but it was generally accepted that the extra wear for that engine (due to the setup) would be almost none.
Moral of the story: They work on some engines without problems, but on others they can really mess things up.
Old Jul 28, 2005 | 03:46 AM
Incubus's Avatar
Most GM engines have a completely seperate harmonic balancer that is to be kept even with an aftermarket pulley.
Old Jul 28, 2005 | 07:01 AM
rsx555's Avatar
This is quite possibly one of the most debated arguments when it comes to mods and always will be. I know people who have run Unorthodox pulleys for 5 + years with zero problems. As unorthodox has pointed out on there website "we would have been out of business years ago, if our pulleys were causing these kind of problems"
The bottome line is, do what make you comfortable. It just irritates me sometimes when information is spread by people who have nothing to back it up with other than " I heard from a friend of a friend of friend who's cousins neighbor had a problem with a crank pulley.
Old Jul 28, 2005 | 08:45 AM
kane.s2k's Avatar
My engine started to make a really loud knocking sound on my civic while reving up really high all of a sudden. The problem was bearing failure on the #1 cyl. I don't think it was my intake that caused that one. Same thing happened to another friend of mine. They don't blow on engines that have seperate balancers. Ours is integrated so I'd definately stay away. Better safe than sorry.
Instaste
Mar 13, 2017 11:27 AM
XxMerlinxX
Jun 20, 2013 03:09 PM
panoscha
Nov 6, 2009 05:46 PM
BahrainONE1
Sep 12, 2005 06:58 PM
