Cruising at 2k RPM
Old Nov 26, 2007 | 11:57 AM
Vik2000's Avatar
Default Cruising at 2k RPM
Ok I don't mean to start another topic craving for how to save gas.
Yesterday after installing K&N FIPK with a great help from my experienced friend, I told him about my fuel efficiency and he said I might be cruising at a too high rpm. I do my shifting at recommended shifting point but it seems like I cruise at too high rpm. I drive 60~70km (37~43 miles/km) at 3rd gear going 4~5 rpm sometimes. I was amazed when my friend was test driving my s2k driving 60km at 5th gear and at around 2~3 rpm. He said driving at such low rpm will use much less gas and as long as the car is running smooth and does not start boggle there's no problem running at such low rpm. Is this true?
oh btw I like my new intake, and sounds much better than before.
Old Nov 26, 2007 | 12:12 PM
minimebang's Avatar
60/70km on 3rd gear is a bit too high for crusing .60km on 4th gear is enough
Old Nov 26, 2007 | 12:13 PM
Ed_Grant's Avatar
When the car is just loafing along 2K should be fine. Just don't expect lightning acceleration if you stomp on the throttle w/o downshifting a couple O' gears.
Old Nov 26, 2007 | 12:20 PM
Vik2000's Avatar
Ohh... yea he was downshifting a lot whenever he needed to accelerate. I wish I could shift so smooth and revmatch like that. Gotta prac more. Thanks a bunch for the replies.
Old Nov 26, 2007 | 12:28 PM
GPWhiteS2kFTW's Avatar
I cruise around at about 2-3k rpms.
Probably the reason I get 26-28mpg.
Old Nov 26, 2007 | 12:29 PM
minimebang's Avatar
our car has got the smoothest tranny out there my frd. the real power band of ours is around 4500 above, but since we hv 9k, i think crusing at 4-5k is too high for me and it really eat up alot of gas. The gas is so expensive this month, i barely hit the glory band lol...6k up..
ps: u will definitely feel heat soak with ya FIPK when
u stay still in a traffic. its like the throttle isnt responding properly, but once you get moving, 5 sec after will be ok.
Old Nov 26, 2007 | 12:42 PM
omg516's Avatar
I think once you drop below 2k rpm the motor starts to bog a bit under load. 2-3k sounds right to me, 4-5k while cruising is just wasting gas imho.
Old Nov 26, 2007 | 12:45 PM
hirev's Avatar
i use 2k on the tach as a minimum, ususally i am in a higher rev band than 2k, but can cruise all day there.....so i go to 6th at 45 mph as example except when climbing up a hill or trying to merg on the freeway, then i downshift. no need to wind the engine out in every gear all the time.
Old Nov 26, 2007 | 12:46 PM
highwaystardoritos's Avatar
go buy a versa
Old Nov 26, 2007 | 12:50 PM
hipopkboy's Avatar
i usually curse around 3.5-4k rpm @ 35-40 mph thats gives you the gas/power combine, i shift up to 5th once it go over 43-45 mph, just my opinion, i dont think our car wants to "GO" even cursing @ 2k RPM so i never drive my car with that low of an rpm unless i roll from a start or up hill
