Cumbersome OEM top cover
If the designers had located the inboard snaps away from the area where the front top latches end up folded, there would be more hand clearance available and the cover could probably be put on quicker.
Originally posted by Suphawk
Is it just me or does anyone like using the OEM top cover. I just put the first scratch on my new car with those darn metal tab snaps
I barely use it.
Originally posted by joeschmoe714
does the OEM hardtop change the blindspot factor of the car vs soft top?
(I know, I know, everybody likes a little...)In proper answer to your question, it may a little since there's a bigger rear window but you would still have a huge B pillar so?! (someone w/ a hard top needs to comment)
Travis
yep - I thought I'd like to use it more often - looks & dust/pollen/UV light protection- its certainly a PITA - I've gotten to a place where when I do use it i can get it on pretty quickly...but why have the fastest power top in the category get slowed down by the manual cover - poor design IMHO - and the weight savings rationalization is not sufficient for me - so I have found I'm using the cover less & less...
