Dashboard making noises!?
Old Apr 2, 2002 | 10:10 PM
vin02s2k's Avatar
Default Dashboard making noises!?
is it just me or did you guys ever had this problem!? whenever I start my car in the morning and warn up the car. after I took off start driving and when I down shift and decelerate the car the dashboard always make this vibrate noises. it only happened during around 2000RPM...
but sometime when it's in normal weather it never make that noise... I don't know is it normal or it's because the weather?? it really bother me a lot and I hope maybe you guys can help me out!? thanks.
Old Apr 2, 2002 | 10:18 PM
RWD_RCKT's Avatar
Two things:
1.) Did you have LoJack installed on your car? I had it installed on mine and that was what made noises in my car... but it was all the time.
2.) The only thing I can think of for cold weather only vibrating sounds like a snap fitting that is just a little loose...so when it is cold the plastic shrinks and a gap opens up...then as your car gets warmer... the plastic heats up and expands. Take it into the dealer... get your warranty's worth!!!!!!
Old Apr 2, 2002 | 10:22 PM
Suzuka2k's Avatar
I'm hearing a similar....rattle....around 2000 rpm on a moderately bumpy road...has a hollowness to the sound...will talk to mechanic next service.
Old Apr 2, 2002 | 11:32 PM
Shinji's Avatar
I have an 02' also. I believe this is the "Technical Service Bulletin 054." And you can have it fixed under warranty. Correct me if I'm wrong.
Old Apr 3, 2002 | 01:13 AM
vin02s2k's Avatar
really!?
what happen when i go tell Honda? it doesn't happen all the time... i have to show them the proof
Old Apr 3, 2002 | 02:19 AM
AVXs2000's Avatar
[QUOTE]Originally posted by vin02s2k
[B]is it just me or did you guys ever had this problem!? whenever I start my car in the morning and warn up the car. after I took off start driving and when I down shift and decelerate the car the dashboard always make this vibrate noises. it only happened during around 2000RPM...
Old Apr 3, 2002 | 08:46 AM
vin02s2k's Avatar
maybe because I didn't notice that...how obvious is the vibrate noises??
hey AVXs2000, the noise was pretty obvious... but it will go away after the car is driven awhile... but IT IS STILL VERY ANNOYED
can someone please let me know if this is under the warranty if so, how would i tell my service guy??
Old Apr 3, 2002 | 09:29 AM
Suzuka2k's Avatar
[QUOTE]Originally posted by RSXTypeR
[B]I have an 02' also.
Old Apr 3, 2002 | 11:46 AM
HPhan's Avatar
I have an '02 with 700+ miles. I always try to keep the RPM below 4K when the engine is "cold" and I am quite sure that the engine operates around 2K quite often. Don't notice any dashboard noise. I'll turn the radio off to check this out the next time. Temperature is mostly around 40s F in the morning, 60s F when I head home from work.
Old Apr 3, 2002 | 11:58 AM
mdb's Avatar
mdb
noticed similar noise in the past. i played with everything...then one day i was actually cleaning the front window and the little plastic thing fell off from behind the rearview mirror. i put it back in place without thinking about. a week later i realized no more noises...
coincidence...maybe...
