Did I do a no no?
I am a fairly inexperienced manaul driver.
I was test driving a 2000 S2000 and was rowed through the gears, 1-2-3-4-5-6. From 6th I was going about 50 mph and wanted to be in 4th. So that's what I did. I got quite a kick when I went from 6-4th, should I have double clutched, or went to 5th first?
That's not really a no-no, but you could've done better to avoid the jerk. What you could've done is tap the throttle while the clutch is pushed in, thereby raising the RPMs to where they would be in 4th gear. Then, when you let the clutch out and engage the gear, it will be a smooth transition.
you sure you didn't go from 6th --> 2nd? 6th --> 4th when you're doing 50mph should really give you concern. in general what you want to do is rev match. if you're in a higher gear you're rpm will be low...when you shift to a lower gear the rpm will be higher at a given speed. so if you don't match the rev you'll get that little kick, which normally isn't a big deal except if you're going fast you might lockup. don't really need to double clutched, we have synchros for that
Originally posted by Islander
rev match
rev match
Now go have some fun.
Mannn
Oct 24, 2006 09:50 AM
