Did you know aboout the key beeps?
Old Feb 16, 2006 | 09:12 AM
Ruined 2's Avatar
Default Did you know aboout the key beeps?
All Hondas for many years (at least 20) have had the four short "beep beep beep beep" sound if you leave the key in the ignition and open the door. Four dots is Morse Code for the letter H, for Honda.
I found this on NSXPrime. The source seems pretty reliable.
Just more worthless trivia to clog up your mind .
Old Feb 16, 2006 | 09:17 AM
01BerlinaS2K's Avatar
Hmmmm........why can't it beep "H" in morse code when u win a race?
Old Feb 16, 2006 | 09:25 AM
ruexp67's Avatar
Well, Dot, Dot, Dot, Dot is in fact H. That at least is true
Old Feb 16, 2006 | 09:27 AM
Cyclon36's Avatar
Brilliant!
Old Feb 16, 2006 | 09:28 AM
Ruined 2's Avatar
Did you hook up the finish line sensor in the front end behind the tow hook cover to the ignition switch?
Well there's your problem.
Old Feb 16, 2006 | 11:04 AM
S2000GT's Avatar
it would be my guess that this is more coincidence than anything else!
Old Feb 16, 2006 | 11:06 AM
SpitfireS's Avatar
We need an Acura owner to check the beeps in/on his/her car.
Should be like Beep.. Beeeeeeeeeeeeeep.
According to the morse code alphabet.
Old Feb 16, 2006 | 11:12 AM
rioyellows2k's Avatar
It also sounds like my cheapass alarm clock.
Old Feb 16, 2006 | 11:15 AM
Ruined 2's Avatar
Aw c'mon. Where's your imagination, your sense of mystique?
And my NSX does the same thing, 4 beeps. It is a Honda after all. I can't see customs changing them all on the docks to "beep beeeeeeeeeep" .
Old Feb 16, 2006 | 11:17 AM
ruexp67's Avatar
You probably don't believe in Santa Clause, the Easter Bunny, or the Tooth Fairy either.
