Diff. Fuild
Old Jan 20, 2004 | 05:56 PM
oneboy2c's Avatar
Default Diff. Fuild
Anyone know which diff fluid i should use from honda or is there a better aftermarket one? thank you
Old Jan 20, 2004 | 05:59 PM
RazorV3's Avatar
definately do not use the honda differential fluid, the vtm-4(PILOT) and dual pump fluid(CRV) are not suitable for our differentials. go to advance auto parts and pick up a bottle of mobil 1 75w90 gear oil for like 8 bucks(silver bottle with skinny squeeze tip). its one of the best you can get, and is readily available.
Stratocaster's Avatar
Try clicking on this link
Look at the last few threads in that list.
Old Jan 20, 2004 | 06:05 PM
s2ksimon's Avatar
yes, do a search, as it's a highly discussed topic. But I too concur with the Mobil 1.
Old Jan 20, 2004 | 06:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Mobil 1...Great choice, readily avail...also try Redline, Amzoil
Old Jan 21, 2004 | 05:50 AM
StknCaS2k's Avatar
How difficult is it to change the Diff fluid yourself? Is there a drain plug and fill plug on our Diff.'s? Also, what is the fluid capacity?
Old Jan 21, 2004 | 06:08 AM
Hockey's Avatar
All this info and more is readily available in the library.
There is a DIY for fluid changes that is VERY complete, with fluid choices, quantities and tools required.
Enjoy!
Old Jan 21, 2004 | 07:58 AM
golfnut311's Avatar
StknCaS2k,
Changing the Diff Fluid is not a big deal. I bought a pump especially for this prupose - You will need on unless you can put your S up on a lift. I forget what I piad for the pump, but it was pretty cheap. Look or ask for on at a reputable Auto parts shop.
Yes, there is a drain plug and fill plug. They are different sizes, so you will need two different size wrenches. Again, I forget what sizes they are (heven't done mine in a while), but searching this site will turn up great information for you (that's where I got all of mine).
Total process takes about 30 minutes or so. Not a real big deal. Just make sure you put int he right fluid, recommended by Honda or you "might" have problems with your warranty later on. I have found that Honda is very sticky when you use after market parts instead of Honda parts for your car. Good Luck.
Old Jan 21, 2004 | 08:46 AM
Billman250's Avatar
Top Answer: 1
Call a few dealers on dif fluid recommendations for the S2000. You can bet your ass you'll get no useful info.
Old Jan 21, 2004 | 09:22 AM
Hockey's Avatar
Ditto
