differences between f20 and f22.
Old Feb 15, 2006 | 07:03 PM
sui_generis's Avatar
Default differences between f20 and f22.
just wondering. both the f20 and f22 have the same horsepower, with the f22 having a bit more torque.
question is, with .2 liters of displacement added on where's the aditional power?
my guess is that they used a milder cam to go along with the lower rev limit. or, they simply made the intake/exhaust paths more restrictive, anyone really know for sure?
thanks
Old Feb 15, 2006 | 07:40 PM
Intrepid175's Avatar
thanks
Formula for calculating horsepower = torque X rpm / 5252.
The F22 makes a little more torque, thanks to it's longer stroke. But, because of that longer stroke, it can't as easily spin as fast. The numbers just cancel each other out for the most part.
Honda wanted to improve sub VTEC performance, which it did with this engine and it's change in transmission ratios, but I don't think they ever wanted it to significantly outperform the F20 in all out performance. It's proven to be a reasonable compromise for most of us. Some prefer it and others don't.
Personally, I don't think you can go wrong with either one.
Drive Safe,
Steve R.
Old Feb 15, 2006 | 07:57 PM
awesome. thanks man.
Old Feb 15, 2006 | 11:40 PM
passmans2kny's Avatar
it makes full horse power and torque sooner, liek 2000 rpms sooner than the f20c, also with torque, just sucks it doesnt rev to 9000 nemore
Old Feb 16, 2006 | 06:21 AM
Wisconsin S2k's Avatar
uhm, no.
the peak power and torque on the F22 is only a couple hundred rpms before the F20's peak. where on earth did you get 2000rpms?
Old Feb 16, 2006 | 06:39 AM
If I'm remembering correctly, the peak hp and torque numbers occur at:
F20 - peak HP is at 8300 rpm and peak torque is at 7500 rpm.
F22 - peak HP is at 7800 rpm and peak torque is at 6500 rpm.
That 500 rpm difference on the HP and 1000 rpm difference on the torque.
FWIW.
Drive Safe,
Steve R.
Old Feb 16, 2006 | 10:44 AM
pexcellence's Avatar
What year model has the f22 engine?
Thanks,
John
Old Feb 16, 2006 | 10:55 AM
Thanks,
John
The F22 engine was introduced, and has remained in production for 2004 thru 2006 North American (US and Canada) models only. The rest of the world kept the F20. All other modifications that were introduced in 2004, as far as I've been able to tell, were implemented world wide. If I'm wrong on some of that last part, I'm sure someone will correct me!
Drive Safe,
Steve R.
Old Feb 16, 2006 | 11:15 AM
QUIKAG's Avatar
To my knowledge, the Japanese market is now using the F22 for MY2006.
Old Feb 16, 2006 | 11:54 AM
So which engine is better, reliable, more fun?
John
