Different tire pressures
Old May 6, 2002 | 01:26 PM
ChiSuzuka's Avatar
Default Different tire pressures
Does running my car for 2000 miles with different tire pressures have a bad effect on the car? I picked up my car mid-March ($30,260 including del charge), and racked up 2k miles the past few weeks. While I was washing the car last weekend, I decided to check the tire pressure, guess what? 4 different tires, 4 different psi.. I think its 55, 47, 51 and 45, I was so pissed at the dealer for not even knowing the correct tire pressures. Anyway, I released the air so that all tires are now 32psi (thats the recommended, right?), ride is sooo much smoother now..
So, any bad effects?
Old May 6, 2002 | 01:34 PM
DarioManfretti's Avatar
[QUOTE]Originally posted by ChiSuzuka
[B]Does running my car for 2000 miles with different tire pressures have a bad effect on the car? I picked up my car mid-March ($30,260 including del charge), and racked up 2k miles the past few weeks. While I was washing the car last weekend, I decided to check the tire pressure, guess what? 4 different tires, 4 different psi.. I think its 55, 47, 51 and 45, I was so pissed at the dealer for not even knowing the correct tire pressures. Anyway, I released the air so that all tires are now 32psi (thats the recommended, right?), ride is sooo much smoother now..
Old May 6, 2002 | 01:43 PM
PLYRS 3's Avatar
damn, those are HIGH!!!!!!!
i've never known a passenger tire to be able to take 57 psi without bursting!
isn't max. pressure something like 48 cold?
is your gauge accurate?
Old May 6, 2002 | 01:48 PM
ChiSuzuka's Avatar
I let the car cool down for more than 3 hours before I took measurement. With regards to the accuracy, I tried the gauge on my friend's car (Acura TL) and it registered a 32psi. Does tire pressure change if the car is on an incline, btw?
Old May 6, 2002 | 01:51 PM
Schatten's Avatar
incline will not matter. just let them cool down. re-check them. try setting them between 36 and 38lbs COLD - all the way around. its a good start to check for suspension balance on this car, IMO.
paivag
Oct 7, 2005 07:40 AM
J-me
Aug 31, 2005 12:31 PM
zking786
Jun 14, 2005 09:25 AM
Thomas Guide
Feb 6, 2005 09:58 AM
AbRcromBcrew
Feb 13, 2002 11:26 PM
