Differential Slam!
I took a friend out last night to show just a little bit of what the S-CAR can do. I didn't drop from the start but instead romped it at about 4000rpm in first. Looked good when I speed shifted to 2nd and the differential slamed against the undercarrage. There wasn't but a total of about 350 lbs. total weight. Is this normal. I have seen this in old mussle cars with a lot of weight.
Originally posted by Sev
How do you know that this happened? Is it the noise it makes?
Originally posted by TRICKS46
No, didn't break, it just came in contact with the underside of the car.
Originally posted by cdelena
I think you are hearing something else. The differential is mounted in a subframe and does not move around like in an old solid axle car.
Insomniak
Mar 19, 2002 08:07 PM
