Do I have to replace the entire rotor?
Old Jan 11, 2007 | 12:17 PM
purehonda's Avatar
Default Do I have to replace the entire rotor?
Someone loosened all five of my lugs. Now one broken off.
I tightened the other four is it ok to drive like this until fixed?
Photos:
Thanks all!
Old Jan 11, 2007 | 12:22 PM
BowlofRice's Avatar
studs can be pressed or pounded out. but i've seen plenty of cars drive without all their studs. some with only 3! i'd say take it slow and go to wherever you need to go to get it fixed.
Old Jan 11, 2007 | 12:32 PM
purehonda's Avatar
The stud. Is it standard for all Honda's with 5x114.3? Or do I have to order a s2000 stud to replace the broken one? Thanks.
Old Jan 11, 2007 | 02:18 PM
Irace4Kimchi's Avatar
wheel stud $1.24each + tax
i think you can do it yourself.
good luck.
Old Jan 11, 2007 | 02:19 PM
honda part# 90113SM1005
check with dealer again.
Old Jan 11, 2007 | 03:32 PM
Chazmo's Avatar
I think you're safe with four lugs for a little while, but I wouldn't do over 50 miles that way.
Old Jan 11, 2007 | 05:42 PM
Spec_Ops2087's Avatar
Finally someone who knows how to take close up shots!
You should be fine with one lug missing, but don't go around doing donuts, burning out, etc (not that you should anyway )
Old Jan 11, 2007 | 05:45 PM
mikegarrison's Avatar
You guys are missing the big picture. If one stud broke, the others are probably ready to break. Get them all replaced, ASAP. Especially since it is a much bigger PITA to get the hub on and off the car than it is to replace the studs once you have it off.
Old Jan 12, 2007 | 08:40 AM
purehonda's Avatar
Thanks all! Will update this thread once I get them replaced.
shiv
Jun 27, 2017 04:06 PM
tdcs2k
Apr 22, 2012 09:53 AM
tua40278
Dec 20, 2010 03:08 PM
J-max
Aug 17, 2010 01:35 AM
SilverSurfer
Jun 13, 2002 10:46 PM
