do used springs settle?
Old Jul 4, 2007 | 11:50 PM
nrgizeman's Avatar
Default do used springs settle?
i've recently installed used eibach springs and have noticed perfectly even fender gaps in the rear and uneven fender gaps in the front. driver side seems to be 1-2 cm lower.
i have searched this forum and found few w similar prob but lacks detail. after reading couple posts, i've concluded that either springs are not settled or alignment is off.
so... do used springs need time to settle?
anything i could do to correct this issue? please help~!
Old Jul 4, 2007 | 11:57 PM
METATRON's Avatar
No they don't. Is the front higher than the rear? Alignment is always good. But it is always possible that the fronts are on the rear and vice versa.
Old Jul 5, 2007 | 12:14 AM
blackout's Avatar
used springs have already settled, assuming they are used for more than a couple weeks
Old Jul 5, 2007 | 09:41 AM
plokivos's Avatar
i don't know how the alignment can change the height of the car...
looks like an install problem if anything, unless I've missed something.
Old Jul 5, 2007 | 02:31 PM
nrgizeman's Avatar
after more search, i've found that its common for s2000 to be lower on front driver side. is there any truth to this?
Old Jul 5, 2007 | 03:37 PM
s2krey's Avatar
I have espilars with koni yellows, few months ago i notice the same but figured its was due to that i drive w/o a passenger alot and make a uneven wear on the driver side. But i might have something wrong...soo
lets see how this thread goes.
Old Jul 5, 2007 | 03:42 PM
Project22a's Avatar
Check your preload?
Old Jul 5, 2007 | 04:02 PM
nrgizeman's Avatar
Originally Posted by Project22a,Jul 5 2007, 03:42 PM
Check your preload?
preload is fine.
i think i found a solution. stay tune for verification.
Old Jul 5, 2007 | 04:09 PM
millertown15's Avatar
They might need a day or two to for the spring to seat. My car is a little lower on the drivers side as well. I really dont think there is anything you can do about it.
Old Jul 6, 2007 | 07:14 PM
nrgizeman's Avatar
i give up. there is absolutely nothing i can do. i just re-sat the springs but nothing happened. i dont think alignment would do much.
conclusion:
as other post mentioned, front driver side does seat lower than passenger.
dennisduong
Sep 29, 2011 09:26 PM
Duy118
Jul 15, 2007 09:53 AM
DragonSi
Aug 29, 2006 09:17 PM
s2ksks
Mar 23, 2004 07:24 AM
tenblade2001
Jun 23, 2003 06:47 AM
