Does every s2k do this?
idk if every s2000 does this, but sometimes when im stopped and put in 1st gear it will make a loud clunk sound, i have an 05 wit 40,000 miles is that jus how the trannys sounds or is there somthing wrong with my car????
It happens when you're stopped right? From Neutral to 1st it makes a "clunk" as soon as the shifter goes into first right? I think it's just the gearing shifting into position. I have it on my '07 with 23k miles...I've never been worried about it.
clunk noise when you put it in gear? thats your tranny. if you simultaneously push down the clutch and put it in 1st gear you will get that noise. it's normal. you're not letting the transmission enough time to stop spinning before putting it in gear. try holding down the clutch for a couple seconds before you put it in gear and you won't hear it.
That's due to the mainshaft in the transmission coming to an abrupt stop when you put the tranny into gear.
If you leave it in gear when coming to a stop and leave the clutch engaged, it will slow down the mainshaft as the engine slows down and reduce the clunk the next time you put it into 1st. If you disengage the clutch at a high RPM, the mainshaft will take a long time to slow down from this speed and will cause a hard clunk if you put it gear before it does.
