Does size matter?
Old Jan 13, 2007 | 09:08 PM
Gatsbee13
Guest
Posts: n/a
Default Does size matter?
I've had my eye on Enkei J10 wheels for a while. Im deciding to purchase them in a set of 17's or 18's. does anyone know for a FACT that 18's will effect 0-60 in a negative way? or any other ride characteristics? I heard that 17's are the optimal size for the S. Also the wheels are only offered in an unstaggered size but the salesguy recommended doing a staggered tire setup. So larger tires in the rear but unstaggered wheels. Whats the best combo? I love the look of the 18's but i dont want too much of a negative impact. Will the 18's have a large impact on performance? Anyone have experience or is knowledgeable about this circumstance? i just cant trust the sales guy. Thanks -David
Old Jan 13, 2007 | 09:11 PM
Enthralled's Avatar
yes,depending on the wieght of the wheels...it'll make a difference on the 0-60 time.are you a drag queen?if not just buy em.
peace
Old Jan 13, 2007 | 09:15 PM
Gatsbee13
Guest
Posts: n/a
No ive never raced my S since ive purchased it about 9 months ago. But I do punch it every now and then. Plus I want the satisfaction of knowing that I can take a Porsche Boxster when it comes down to it. But I know alot of people on here run 18's.
Old Jan 13, 2007 | 09:22 PM
Enthralled's Avatar
just get the wheels and get a couple of mods. example: test pipe,gears.etc...
peace
Old Jan 13, 2007 | 09:59 PM
clawhammer's Avatar
My 18" wheels are lighter than my 16" wheels (stock)
Having said that, the butt dyno still says that the 16s accelerate slightly faster. More of the weight is farther out from the center of the wheel, and more force is required to turn that weight since it's farther out in the circle. Someone with a background in physics can explain it better.
Old Jan 13, 2007 | 10:13 PM
rosodigital's Avatar
who drag races anymore?
Old Jan 14, 2007 | 01:40 AM
tbonesteak's Avatar
yeah...seriously ^^^ just get them.
Old Jan 14, 2007 | 06:24 AM
Spec_Ops2087's Avatar
Your talking about a MINIMAL difference between 0-60 times from 16 to 18s. I could feel the difference my testpipe + catback added (about 17hp total) but I could feel no difference between my 16s and my 18s granted they are the same weight just bigger.
I also felt no ride difference...
Old Jan 14, 2007 | 06:36 AM
TB's Avatar
TB
You're referring to Polar Moment of Inertia.
Same concept applies if you try to spin around with your arms fully extended out to your sides with weights in your hands....now try spinning with your arms and the weights pulled in to your chest....much easier.
Most people wont feel the difference going to 18s (depending on how heavy they are though I guess). But most people will notice the difference if/when they go back to 16s.
Like ENTHRALLED said, if you want them and you dont race, just get them and a set of gears and you'll be just peachy
Old Jan 14, 2007 | 12:09 PM
s2ka's Avatar
The diameter makes a big difference on the gear ratio of our low-torque cars. Most 18" tires have a larger diameter than similar width 16" or 17" tires. I could definitely feel that my old 18" set-up was slower than 16" or 17". I switched back and forth several times.
Check Tire Rack for the tire diameter. Here's a photo of a typical 16" versus 18" rear tire.
And the stock 16" versus the stock 17" OEM rear tires:
