door sill question
Old Jan 31, 2004 | 08:04 AM
brerspidur's Avatar
Default door sill question
when i got out of my car the other day, i looked down and noticed that the metal door sill to the left of the driver seat that says s2000 was kinda bowed up on the outer edges of the metal part. kind of the frame of it was bowed in the middle, and i found that i could push down on it, but it wouldnt stay. i would say that it raised up about 1.5 cm. just out of curiosity, i checked the passenger one also and found that it was the same way. has anyone else noticed this problem? or is it supposed to be like this, and i just never noticed it? and if it is a problem, what are some possible solutions?
thanks
Old Jan 31, 2004 | 08:15 AM
fltsfshr's Avatar
Take your doorsill off, the whole piece is only held on by nylon clips..the clips are in sliders, you've either lost one or more likely its under there not getting in the hole.
just pull up it pops off.
fltsfshr
Old Jan 31, 2004 | 08:42 AM
brerspidur's Avatar
sorry, let me be more specific, its not the actual sill thats popping up, its just the metal honda s2000 plate on the sill. unless this has clips on it too?
Old Jan 31, 2004 | 08:53 AM
amongmany's Avatar
That piece is just riveted on. You might be able to bend it back in place, but I think that once you take it off, its a pain to put back.
Old Jan 31, 2004 | 08:59 AM
frycow's Avatar
If I had to guess, I'd say that one of the 2 brads that holds the plate in place is missing. The brads are circled in red below.
Old Jan 31, 2004 | 09:14 AM
brerspidur's Avatar
i checked the brads on one of the plates, they are both in place, it almost looks like they are too close together , for the plate to lay flat. if you look a the picture, it would be the bending on the side that goes in between the brads on the top and bottom, and it arches so the highest point is directly in between the brads . an example would be to take a playing card and hole it between your fingers on the top and bottom, and bend it that way.
Old Jan 31, 2004 | 10:18 AM
shiftright's Avatar
What if you squeezed in some super glue type stuff between the metal plate and the plastic door sill and put a heavy bood on top over night and that should flatten the metal plate in place.
Old Jan 31, 2004 | 10:19 AM
shiftright's Avatar
What if you squeezed in some super glue type stuff between the metal plate and the plastic door sill and put a heavy book on top over night and that should flatten the metal plate in place.
getmadboy
Aug 15, 2009 12:55 PM
ZDan
Nov 21, 2007 02:55 AM
jav8or
Feb 15, 2006 10:47 PM
Xenox
Jul 18, 2005 06:14 PM
NoTorq
Apr 19, 2002 08:46 AM
