Double Clutching
Old Aug 22, 2005 | 05:46 PM
Kyushin's Avatar
Banned
Default Double Clutching
ok i know im gonna get it for this one, but what exactly is this? I was under the impression that it was keeping the clutch in while you shift through more than one gear at a time, but i heard some guys at a shop arguing about it... i know nothing of it so i better ask some pros so i have it straight and not speak up and not sound like an idiot
Old Aug 22, 2005 | 06:12 PM
xviper's Avatar
I could explain it to you but I'm lazy tonight so:
http://www.wisegeek.com/what-is-double-clutching.htm
(Google does amazing things. )
Old Aug 22, 2005 | 06:29 PM
Kyushin's Avatar
Banned
lol wow, and to think i was already doing this on a regular basis..... i feel like such a noob now hahahah
Old Aug 22, 2005 | 06:44 PM
Silver9k's Avatar
I just don't understand the point of it...why not just leave the clutch down...thats what I do, and it works great for me. I'm like Wisconsin in is 4.57 shifting video
Old Aug 22, 2005 | 06:51 PM
xviper's Avatar
There is no point to double clutching on upshifts, assuming you are not skip shifting (which is not recommended anyway). Even for downshifting, there is no point to it UNLESS you are trying to downshift into 1st "at speed". You need to double shift here to defeat the blocker ring.
Old Aug 22, 2005 | 08:06 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
It's dating from the good old days,when there were no synchros,or not very efficient synchros,and was mostly used on trucks for downshifting.
You can also shift,up or down,not using the clutch at all,by matching the revs.
IE:third gear,let off gas,pull shifter in neutral,rev to match,pull shifter in second,no clutch.
same thing for upshift;second,pull shifter in neutral,let the revs fall to match,push shifter in third,no clutch.
Old Aug 26, 2005 | 01:58 PM
victorandolph's Avatar
double clutching = faster way to burn your clutch. so dont try it unless you're BOLD.
Old Aug 26, 2005 | 02:08 PM
hpark's Avatar
don't understand how it would burn your clutch any faster???
as long as you match revs on shifts, should be the same wear and tear on clutch and synchros?
Old Aug 26, 2005 | 02:19 PM
Billman250's Avatar
Active Streak: 120 Days
Top Answer: 1
For the S2000, heel/toe is all you need to be smooth and fast.
Double clutching is for Macks
Old Aug 26, 2005 | 03:47 PM
Slows2k's Avatar
Off to S2000 talk. Not really UTH material.
