dremel and touch up paint repair???
Old Jul 14, 2003 | 08:33 PM
mikecl713's Avatar
Default dremel and touch up paint repair???
anyone give me advice to smooth out touch up paint blobs with a dremel??
Old Jul 14, 2003 | 09:08 PM
JL9000's Avatar
You'll do more harm than good with the dremel.
Try using a sanding block.
Old Jul 15, 2003 | 05:29 AM
wLim's Avatar
Or look for a product called Langka. It's a formulated to remove that unsightly blob after a touch-up paint job. Takes a little practice to get it right, but works really well once you get the hang of it.
Old Jul 15, 2003 | 05:49 AM
DaveFromSydney's Avatar
[QUOTE]Originally posted by wLim
[B]Or look for a product called Langka.
Old Jul 15, 2003 | 09:24 AM
JL9000's Avatar
Guys. It's not that hard to use a sanding block.
1. Clean the area
2. Wet sand until flush
3. Polish
4. Wax
Old Jul 15, 2003 | 11:13 AM
Greg Fisher's Avatar
JL9000,
I have never sanded my car before. Would you be willing to be a bit more specific as to types or #grit actual blocks and what ever else....
I recently hit a piece of road debris and put a small scratch on the OEM lip. I hate the way touch up paint looks but would be willing to try the technique you referred to.
Thanks
Greg
Old Jul 15, 2003 | 03:33 PM
RedY2KS2k's Avatar
Dremel: no way. Maybe if you've got super touch and much experience (spelled ruined several paint jobs along the way)
Many places (www.eastwoodco.com for one) sell "paint nib files" or some such. It's a tiny file (maybe 1" square in a wooden block) designed to file down a run before wet sanding/polishing. I'd look for one of these and keep the Dremel in the toobox.
Old Jul 15, 2003 | 03:39 PM
sebrings2k's Avatar
- wash car
- apply touch up paint using tooth pick or something similar
- go for multiple coats over time rather than 1 coat of thick paint
- use 2000 grit or higher sand paper (use a hole punch and some double sided sticky tape and tack onto eraser side of standard pencil)
- wet sand slowly until flush with surface of car
- wash
- wax
- polish
TAKE YOUR TIME!!!
Old Jul 15, 2003 | 04:13 PM
JL9000's Avatar
Originally posted by sebrings2k
- Wash area with dish detergent or Simple Green
- Dry
- Apply touch up paint using tooth pick or something similar
- Go for multiple coats over time rather than 1 coat of thick paint
- Let dry overnight
- Use 1500 grit sanding block (easier on relatively flat surfaces)
- Wet sand slowly until flush with surface of car (Use car wash shampoo mixed with water as lubricant)
- Rinse area
- Use rubbing compound if there is a lot of hazing, or else just use a strong polish such as Meguair's DACP
- Wax
Sorry I was too lazy to type out the whole procedure so I just took sebrings2k's post and modified it. I hope he doesn't mind.
Old Jul 15, 2003 | 04:15 PM
MyBad's Avatar
- wash car
- wash
- wax
- polish
TAKE YOUR TIME!!!
Ditto!
Also, you can dilute the touchup paint with thinner to make it "flow" better. Multiple coats is the key.
