Drifting defination
Race Drift
This is performed at race speeds, when entering a high speed corner a driver lifts his foot off the throttle to induce a mild over steer and then balances the drift through steering and throttle motions. (note: the car that is being used for this style of drift should be a neutral balanced car therefore the over steer will induce itself, if the car plows through any turn this technique will not work).
Braking Drift
This is performed by trail braking into a corner, then loss of grip is obtained and then balance through steering and throttle motions. (note: this is mainly for medium to low speed corners).
Faint Drift
This is performed by rocking the car towards the outside of a turn and then using the rebound of grip to throw the car into the normal cornering direction. (note this is heavy rally racing technique used to change vehicle attitudes during cornering, mainly tight mountain corners).
Clutch Kick
This is performed by depressing the clutch pedal on approach or during a mild drift to give a sudden jolt through the driveline to upset rear traction.
Shift Lock
This is performed by letting the revs drop on downshift into a corner and then releasing the clutch to put stress on the driveline to slow the rear tires inducing over steer. (this is like pulling the E-brake through a turn - note this should be performed in the wet to minimize damage to the driveline etc.)
Emergency Brake Drift
This technique is very basic, pull the E-Brake or (side brake) to induce rear traction loss and balance drift through steering and throttle play. (note: this can also be used to correct errors or fine tune drift angles).
Dirt Drop Drift
This is performed by dropping the rear tires off the road into the dirt to maintain or gain drift angle without losing power or speed and to set up for the next turn. (note this technique is very useful for low horsepower cars).
Jump Drift
In this technique the rear tire on the inside of a turn or apex is bounced over a curb to lose traction resulting in over steer.
Long Slide Drift
This is done by pulling the E-brake through a strait to start a high angel drift and to hold this to set up for the turn ahead. (note: this can only be done at high speed).
Swaying Drift
This is a slow side-to-side faint like drift where the rear end sways back and forth down a strait.
FF Drift (Front Wheel Drive Drift)
The E-brake as well as steering and braking techniques must be used to balance the car through a corner. (note: the E-brake is the main technique used to balance the drift).
Power Over
This performed when entering a corner and using full throttle to produce heavy oversteer (tail slide) through the turn. (note: needs horsepower to make this happen).
Drifting is that fine line of control just before an uncontrolled skid. In racing, a car is usually considered to be drifting when all of its wheels are slipping, but the front wheels are still more-or-less pointed in the direction of the corner, or at least straight. Beyond that, when the car gets more sideways and even harder to control, it
Braking Drift
Faint Drift
Clutch Kick
Shift Lock
Dirt Drop Drift
Jump Drift
Long Slide Drift
Swaying Drift
Power Over
Nate Tempest
Aug 26, 2018 02:12 PM
