Drilling into the fake side vents
Old Mar 5, 2006 | 02:29 PM
SilverKnight's Avatar
Exclamation Drilling into the fake side vents
I know some people take these out but I really havent foudn this on search to much. For the side vents there are 2 main options I have seen.
Most just cut out the whole vent, others use a type of tube or nozzle insert which makes it look like a rocket launcher
I'm going the middle route. Buy some black side grills from grill tech, drill about 6 medium sized holes toward the center of the fake insert. Then throw the grill on.
The holes could be of some use to brake cooling and also a lil more air flow to CAI but nothing major. I just dont liek the idea of having the duct be non functional Are the fake insert easy to drill through?
Old Mar 5, 2006 | 03:05 PM
S2kracka's Avatar
You won't have a problem drilling/cutting/Dremeling through it. Wear a mask and glasses though, getting that stuff in your lungs/eyes is painful!
Old Mar 5, 2006 | 03:08 PM
CitadelBlue's Avatar
Anyone have any "after" pictures on an AP2?
Old Mar 5, 2006 | 03:16 PM
yeh going to order the side grill tonight then should be doing it when they come in
Old Mar 5, 2006 | 03:28 PM
24s2k7's Avatar
i just used a razor blade and cut out every other section
Old Mar 5, 2006 | 03:29 PM
a lil razor can do it? wow lol drills should be no prob then
Old Mar 5, 2006 | 03:57 PM
S2000GT's Avatar
yeah - its only thin plastic - youll get through it no problem with a razor blade
Old Mar 5, 2006 | 04:27 PM
gomarlins3's Avatar
Dremal tool is your friend. I left a little piece of the plastic there to give me something to screw into to keep the grill in place.
Old Mar 5, 2006 | 04:38 PM
I'll probably just drill several holes or use razor I think If iwere to dremel Id take the bumper off to amke sure paint doesnt get damaged.
Old Mar 5, 2006 | 06:28 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Medium thick plastic,easy to dremel,must be a little hard to cut with a blade.
Cut mine off;just left 2 small tabs,in opposite corners,to screw the grills on.
Check Coastal Metal grills;Full S.S,,and you can get them PCed black or silver.
After pics:
