Dry Nitrous System
I'm thinking of going with the dry NX or Zex system. What accessories would I need to start out with? Does anyone sell a kit with all I would need? I've seen kits, but I really don't know what to buy so I'm not sure if they have all I'll need. Sorry to sound like a lameass. I just don't want to waste my money.
Hey...I have a wet NX kit. Before ya do anything with nitrous please read all ya can on the subject and get a full understanding of how it works and its properties. The dry kits are easy to install......In colder weather a bottle heater is a must hte zex heater....the one i have is lame....only heats the bottle to 800psi....950 to 1000 is better. A pressure guage is also a must! To much pessure from the bottle and damage can occur. If your a street racer an auto opener is a big plus and almost a must for those unexpected stoplight C-5 battles. Besides that your good to go. I'd stay under 50 shot for dry. Change your spark plugs....platnium are no good for nitrous. Iridium are no good either. I tried the zex plug....boy they really sucked bad. Stay away. I like champion copper plus (318 rc12mc4) plugs.....Gap them aggressively.....say .048 to .050.
Anyway feel free to P.M. me with questions!
By the way people have had good luck with zex product...but the two zex products I tried Sorta sucked. The plugs blow i lost a good amount of horse power (20)and my times suffered big time (g-tech measured). I eventually fouled a plug. Thats when i switched to the champions wow day and night difference!
If you try to produce too much power with a "dry" system don't you risk running the engine very lean?
i thought a wet shot would be safer because you are spraying nitrious and gas??? if it is not safer some please explain to me why? thanks
A Nitrous system Can be safe(dry or wet or direct)...But it takes a hardcore dedication to tuning and checking your engine. Its not a install and forget about it mod.
dry systems runs by increasing your fuel line pressure. so say when you go to hit that 40 "shot" of n2o, your fuel rail pressure increases and your injectors squeeze out more fuel. that's it. there aint no brains about it. the thing that happpens with dry set ups is that when you start getting towards "75" or "100" shot areas, your injectors faults start coming into play. how much more pressure can your fuel rail be increased? and injectors all flow at different rates, but when you increase the pressure, it only exagerates teh problem.
wet setups's get around this problem by adding fuel at the nozzle. but, there always problems associated with single nozzle "wet" systems on hondas. if you squeeze too much. say "75", you start tp have fuel puddling, which is no good. you tend to have more run lean conditions with this set up. honda intake manifolds exagerate this problem more with their desgins.
definatly nitrous is not a set it and forget it mod. it takes a bunch of jets, a box of sparkplugs, and a whole lot of runs to tune a nitrous set up right. make sure you keep checking those plugs for rich and lean condition. error on the safe side, because a fouled plug is better then broken rings lands.
ps. don't place the "dry" nozzle to close damnit! =P
