Dyno numbers
Old Feb 25, 2003 | 10:02 PM
Blue Angel's Avatar
Default Dyno numbers
I went to Dynojet (model 248 C) last week and the outcome was 206 on the wheels and 233 on the Crank. Is that good? Why do i have 7 ps less than the factory figure in the crank?
Old Feb 25, 2003 | 10:17 PM
godai's Avatar
How do you measure at crank?
Old Feb 25, 2003 | 10:19 PM
yellafever's Avatar
Banned
206 @ the wheels is somewhat on the high end already. Dynojet also tells the hp at the crank? I didn't know that. If your car makes 206 at the wheels, that's good enough already. You're not really getting ripped off at the crank. HP at the wheels is all that matters. Then just calculate the 15% loss, and you're making about 242 at the crank. Not bad!!!!!!
Old Feb 26, 2003 | 02:32 AM
Blue Angel's Avatar
Thanks yellafever!!
Old Feb 26, 2003 | 02:38 AM
Blue Angel's Avatar
I Do not know godai but Dynojet can measure losses. But keep in mind that the mechanic told me that only wheel power is accurate.
Old Feb 26, 2003 | 04:39 AM
Russ's Avatar
It's not always 15% loss with a manual. For instance, on many BMW's and especially the Toyota MR2-S, drivetrain loss is around 9-11%. My Spyder, stock, dyno'd at 122.8hp Most others dyno in the 120-122 range. I would summize in the Spyder's case, it's the fact that it's mid-engined but I wouldn't speculate on the BMW's, which appear to have very well-engineered and efficient transmissions.
Old Feb 26, 2003 | 06:58 AM
godai's Avatar
I just can't imagine how a dyno can calculate losses/crank power at the wheel.
Old Feb 26, 2003 | 08:45 AM
02spas2k's Avatar
the car will probably get more power to when you are moving because there is more air cooling down the engine. am i right?
MAtt
wanabe
Nov 21, 2007 11:08 AM
wadswoaj
Jul 26, 2007 08:03 AM
bc02
Sep 5, 2006 08:10 AM
atraenk
Jan 19, 2003 10:17 AM
Phast2K
Dec 1, 2001 06:19 PM
