easy trick to tighten top
Old Feb 2, 2004 | 07:44 AM
wanabe's Avatar
Default easy trick to tighten top
o.k.- not trying to take credit for this, but have searched and cant find the original thread that suggested that we use 1/2" piece of airline tubing (from a pet store- fish tank) to slip over the fingers on the latches to tighten them...
i couldnt get 1/2" to go on the part, but did get about 1/4"-
and it really did tighten them!
...tightened them so much it took me quite a while to get the top latches released!
now i need the solution to the "too tight top latches"!- anyone using the tubing got ideas ?
Old Feb 2, 2004 | 07:57 AM
Tegs2k's Avatar
Nice! Thanks for the tip.
Old Feb 2, 2004 | 08:03 AM
PortugueseS2K's Avatar
you mean slipping the tubing on the hook that is attached to the latch? hooks into the top of the inside windshield im guessing thats a great idea! Thanks for the tip
Old Feb 2, 2004 | 08:07 AM
wanabe's Avatar
[QUOTE]Originally posted by PortugueseS2K
Old Feb 2, 2004 | 08:11 AM
Cool, thanks again i have some rattling coming from the passenger side latch whenever i go over bumps or unsettled pavement. maybe this will cure it
Old Feb 2, 2004 | 08:21 AM
efthimios's Avatar
will that lead to over stretching the top over time..enough to cause any type of problem?
Old Feb 2, 2004 | 08:42 AM
payyourtoll's Avatar
can someone snap a pic of this? Im lost
Old Feb 2, 2004 | 09:06 AM
wanabe's Avatar
Cool, thanks again
Old Feb 2, 2004 | 09:55 AM
BlitzSRM's Avatar
I think this would deteriorate the Rubber Seal.
I saw in another tread stating, while the S is in Storage keep the latched unlocked so the Rubber won't get smashed.
I know this suggestion is not for storage, but the effect will result in smashing the rubber even more....I would do this if there is a leak, but to stop rattling.
Old Feb 2, 2004 | 11:07 AM
GaryRudolph's Avatar
FYI, there was a thread at one point that talked about using the adjusters to do this... They're near the roll bars after you remove some plastic and can adjust the top latches if I recall. PITA to take a part and do it, but... you could get it "perfect".
