Eibach ProKit Question, HELP!!!
Old Apr 22, 2004 | 08:30 PM
YELOSCREAMER's Avatar
Originally posted by chrisho
For us newbies trying to insall springs/shocks ourselves for the first time, how do you go about pre-loading the suspension prior to tightening everything up?
Basically you need to "snug" up your suspenson but do not tighten it untill you have a load on the suspension. I was lucky and did mine on an allignment rack. This made getting to everything pretty easy. I would think if you have your car supported with jackstands that you could use a floorjack to load your springs.
Old Apr 23, 2004 | 07:11 AM
ninegrand's Avatar
I can't find the exact thread(s) but if you d a search you will find at least a couple that talk about everything to do and look out for when installing springs.
If I find it I'll link you
Old Apr 23, 2004 | 07:31 AM
JamieS2K's Avatar
I have eibach pro's and the front is lower than the back, you may get a slight rub too if you hit any holes in the road a thigh speed
Old Apr 23, 2004 | 07:33 AM
JamieS2K's Avatar
[QUOTE]Originally posted by Formula
I recently put 18"s on the car and had a shop lower the car with the Eibach prokit.
wanabe's Avatar
also should prob roll the fenders to avoid the rubbing with 18s...
Old Apr 23, 2004 | 07:35 AM
JamieS2K's Avatar
What is roll the fenders ?
Old Apr 23, 2004 | 07:38 AM
wanabe's Avatar
roll the fenders means the lip gets bent in a bit with a roller that is made for this purpose... this is standard for any oversize wheels- you can rent fender rollers usually.
btw, one of our members works for eibach... so pm him with questions:
vtecvoodoo
Old Apr 23, 2004 | 07:50 AM
JamieS2K's Avatar
vtecvoodoo
thanks I pressume this stops the slight rub, does it bend them out as my wheels stick out a little ?
Old Apr 23, 2004 | 08:42 AM
wanabe's Avatar
[QUOTE]Originally posted by Jamies2k
Old Apr 23, 2004 | 08:47 AM
reds2k1's Avatar
Using a floor jack, would you just place it under the shock assembly and just raise it a bit and then tightening the bolt on top? Is this the only bolt that is of concern or are there others?
Thanks!
[QUOTE]Originally posted by YELOSCREAMER
