Endless 6 piston calipers
Old Oct 28, 2006 | 09:08 AM
midnightmethane's Avatar
Default Endless 6 piston calipers
I' thinking of buying Endless Big Barke Calipers (6 piston) from the for sale forum and i want to know if they will fit AP2 wheels without spacers....i absolutely do not want to change anything....it has to be a staright bolt on....will they fit??....thanks in advance
Old Oct 28, 2006 | 09:11 AM
Ustemuf's Avatar
i am 100% sure they wont fit without spacers, those brakes are monsters. if spoons cant fit stock without spacers i dont see how those could.
Old Oct 28, 2006 | 09:19 AM
spoons won't fit either...are you sure??? cause i would also be interested in those....they'd be cheaper...although i might have a pretty good deal on those endless ones...but def. no spacers
Old Oct 28, 2006 | 09:32 AM
SpeedxRacer's Avatar
Going to need spacers.
Old Oct 28, 2006 | 09:37 AM
ahhhhhhhhh...that's a nightmare...what about with aftermarket rims from tire rack??
Old Oct 28, 2006 | 09:39 AM
Ustemuf's Avatar
yes the endless will fit with aftermarket rims, depending which ones you get and which offsets... i'd recommend contacting ASMSpec - https://www.s2ki.com/forums/index.php?showuser=4621
he seems to be pretty knowledgeable with the endless calipers having first hand experience. in an older thread he listed these wheels clearing the endless with no spacers
Racing Hart CPFtuner
17x7.5 +43
17x8.5 Forgot the rear offset
SSR GT7 (SCCA Spec)
17x7.5 +50
17x8.5 +63
Old Oct 28, 2006 | 10:49 AM
FOPAUL13's Avatar
quick question...are there any downsides to spacers? i want a bbk as well, but don't want to change wheels...if this is a hijack, let me know and i'll start my own topic...tia...
Old Oct 28, 2006 | 11:11 AM
DC_AP1's Avatar
Wedsport SA90 17x7.5 +43 will fit with a 3mm spacer
Wedsport SA70 17x7.5 +43 will fit without any spacers.
Mugen MF10 17x7 +38 will need a 25mm spacer!
ADVAN RS 17x9 +35 will with without spacers (J's fenders only)
Dickson
Old Oct 28, 2006 | 11:14 AM
DC_AP1's Avatar
If you don't change to longer studs, the thicker the spacer, the less threading you have for the lug nuts to screw in; which means the wheels will have a bigger chance of falling off. Yes it will happen and it did to my friend a few weeks ago.
He should have known better, but he still did it anyways and it was funny.
Dickson
af1981
Feb 15, 2014 08:23 AM
Polemicist
Apr 23, 2008 06:35 AM
midnightmethane
Aug 15, 2007 05:28 AM
Salec
Jan 17, 2006 05:43 AM
goowattjuy
Aug 8, 2005 11:30 AM
