Engine VIN plate
Old Sep 30, 2014 | 04:40 PM
TeslaChicken's Avatar
Default Engine VIN plate
I'm going to see a MY09 tomorrow that's a little too suspicious to be true. 50k miles for $22k at a stealership.
I've read about the MY09 and its engine issues, and after asking a rep over the phone, he very promptly responded that the VIN on the engine matches that of the car (how he knew, I don't know).
Anyways, I'd like to check and see if it has a new engine in it - where exactly can I find the little green riveted plaque? Should I bring one of those extendable mirrors with me? I figured it'd be good to know in general where the plaque is for future reference as well.
Old Sep 30, 2014 | 04:53 PM
daileyboy81's Avatar
You will need an extendable, flexible mirror of some type or the vin cannot be read. I used one to find my engine vin, that's when I found out my motor wasn't original after I bought my s2k. It is located on the back of the head close to the firewall and facing the firewall. You may also need a flashlight and a cell phone to snap a pic. It's easier to access on the passenger side. Good luck!
Old Sep 30, 2014 | 05:15 PM
Do you think one of these types be enough to tilt and see it?
Old Sep 30, 2014 | 05:25 PM
^ Those will work well!
Old Sep 30, 2014 | 05:32 PM
Perfect then, thanks!
Will the plate be parallel on the head to the firewall, would you know by any chance?
Old Sep 30, 2014 | 05:45 PM
Yeah. You will have to look at it from above, so it will appear upside down and backwards in the mirror. I'd just try to grab the last 4 because it might take a bit to keep adjusting the mirror position. It's a tight space.
Old Sep 30, 2014 | 05:46 PM
Perfect, I appreciate it!
Old Sep 30, 2014 | 07:43 PM
Soof's Avatar
What are the engine issues with the '09? I'm unaware there were any problems.
Old Oct 1, 2014 | 03:17 AM
Several isolated incidents: metal debris in the oil pan after a bad sounding noise coming from the engine at around 2-2.5k rmps. Other owners needed new engines to be put in. That's what I've read around the site, there might be more I'm not aware of?
Old Oct 1, 2014 | 03:51 PM
Orjinal's Avatar
IIRC the 09 engine problems were on JDM/EDM f20c's.
