Ever have your shift knob twisted?
Old Nov 2, 2001 | 07:16 AM
MKH's Avatar
MKH
Default Ever have your shift knob twisted?
sounds erotic i know, but its not
so on the way to work this morning, i noticed that the numbers on the shifter were twisted 90 degrees to the left, pointing towards me. I tried unscrewing it, and putting it on at different points, always ended up facing the left. I have no idea how I can get it centered again. Any ideas? TIA
Old Nov 2, 2001 | 07:18 AM
seung's Avatar
turn it into the correct angle, than twist the bottom "black" knob/ nut tightly.
Old Nov 2, 2001 | 07:31 AM
MKH's Avatar
MKH
turn what though? looks like i'll need some pliers to grip it, but Im not sure wheres a safe place to twist it. Problem is, I cant twist it left from the knob, because it just unscrews it
Swurvydel's Avatar
mine are still the same since day one...perhaps it wasn't tight when you got it from the dealer
Old Nov 2, 2001 | 07:57 AM
1Y2KS2K's Avatar
Use a wrench and slacken the nut on the base of the knob about one turn (clockwise I believe). Screw the knob as far down as it will go, then back it off until the pattern is lined up O.K. Hold it there while you screw the nut up tight.
Old Nov 2, 2001 | 07:58 AM
MKH's Avatar
MKH
[QUOTE]Originally posted by 1Y2KS2K
[B]Use a wrench and slacken the nut on the base of the knob about one turn (clockwise I believe).
Old Nov 2, 2001 | 02:41 PM
moyopoyo's Avatar
i'm not sure if yours is new or not, but i do know that when i got mine from the dealer, it was pretty loose, and i just tightened it myself.
Old Nov 2, 2001 | 03:18 PM
yu888's Avatar
mine actually came loose after 22 months...or maybe it was from when I installed the leather center console cover a few months back, but I just re positioned it, and cranked the lock nut up against the knob and it is perfect again!
Old Nov 2, 2001 | 05:27 PM
MyBad's Avatar
Yep! Every chance I get!!
Old Nov 2, 2001 | 05:36 PM
dlq04's Avatar
Originally posted by MyBad
Yep! Every chance I get!! [/B]
You wish!
