exhaust tips on the AP1
Old Feb 1, 2017 | 12:59 PM
robertmeredith's Avatar
Default exhaust tips on the AP1
I picked up a used AP1 exhaust this week and was floored to discover the bolts holding the tips on appear to be welded. Anybody else run into this?
If I want to get the tips off, it appears I'll need to get in there with a dremel tool and try to grind the weld off the base of the bolt heads.
Old Feb 1, 2017 | 01:05 PM
TofuProductions's Avatar
Factory welded?? Not sure.
edit: Apparently they are not welded!!
Old Feb 1, 2017 | 04:56 PM
Hfreak's Avatar
Welded? I have removed tips from both an AP1 and AP2 exhaust by unthreading the bolt, although I have had one seize and snap on me.
Good luck.
Old Feb 1, 2017 | 09:53 PM
zeroptzero's Avatar
^ yeah they are not welded on in factory form, very easy to swap. It might be possible that someone welded them on for a specific purpose, but it does not come like that in oem form. Put a 10mm socket on the bolt and try to loosen it up, maybe you aren't seeing it properly ?
Old Feb 2, 2017 | 03:30 AM
Really?
Odd.
I've seen mine and two other AP2s that were all welded on.
Now I am intrigued.
Old Feb 3, 2017 | 07:00 AM
CoolGuy094's Avatar
All of the OEM exhausts and tips that I've owned have NOT had the bolts welded. But like others, some of them have been seized.
Old Feb 3, 2017 | 01:26 PM
Mystery solved! Thanks for the good feedback. I purchased new flange bolts today (10mm?) and discovered each bolt has a shoulder at the bottom of the head. What I mistook for a weld was the deterioration of this shoulder where it meets the surface of the flange on the exhaust tip. Both sides appear seized ....Hopefully a bit of Blaster will help convince 'em to come off!
climhazzard
Jan 28, 2018 11:26 AM
Pinky
NES2KO Marketplace
Apr 7, 2012 01:30 PM
durmz
Feb 26, 2012 04:16 PM
F22Cast
Apr 6, 2009 06:54 AM
