Faster with top down
Can't see video on my phone. OP mention that similar results are observed on other convertibles.
My hypothesis: the top down does lower the center of gravity. There maybe some negative effects on aerodynamics as well. However, tsukuba isn't a very high speed track, the aerodynamics factor likely did not matter as much as the center if gravity.
Besides, a non-negligible drop in CG height requires a complete re-tune of the suspension in order to optimize it to the new CG.
1. I'm not convinced that the S2000 makes any downforce, stock. Really, few production cars actually make downforce, and even then they are likely either exotics or have some big-ol' wings on them.
2. I'm not sure what a "negitive [sic] drag coefficient" is and I'm not getting your analogy.
3. Again, data from wind tunnel testing tells the whole story. For those that want to find out, pool up some money and rent a wind tunnel for a few hours. Otherwise, all we're doing is guessing. With that said, some guesses are better than others.
track times arent conclusive here...a good wind tunnel drag coefficient test would be the most certain way to find some valuable data here.
It has been proven time and time again that the S2000 has less drag if the top is up vs down.
Originally Posted by LeonV' timestamp='1357333444' post='22246186
Also, the cars' drivers ultimately dictate the lap times. If the driver, for any reason, feels more comfortable with the top down (better visibility, easier to hear tires losing grip, etc.), it will result in faster lap times.
Originally Posted by billios996' timestamp='1357326090' post='22245880
More drag could yield more downforce. Less drag with a roof but no wing could be detrimental to cornering speed.
In this case, the top being down could create a bigger wake, i.e. low pressure area, behind the windshield and above the car. This would create lift, not downforce.
Drag does not create downforce, but rather creating downforce can cause drag (emphasis on "can").
I do have two degrees in aerospace engineering, FWIW (not that that makes me right).
I don't agree with the driver comfort theory. For one thing, I'm more comfortable at the track with the top up (my faster primary track cars have been coupes).
I would still bet at most tracks that top up is faster, certainly true for miatae, anyway.
