First Act of Vandalism, help!
Old Mar 9, 2002 | 10:53 AM
Psicho54's Avatar
Default First Act of Vandalism, help!
Well it finally happened ... some idiot decided to take a black permanent marker and mark an area by the front emblem. I mean ... what the hell is the point of doing something like this? Pure jealousy I guess.
Anyway, I was wondering if you guys knew of any substance/chemical that I could use to remove the permanent marking? Any advice/suggestions would be appreciated. (The area is more or less 4 square inches.) Thanks in advance.
Old Mar 9, 2002 | 11:09 AM
M3KVB's Avatar
I would try mineral spirits. It will not hurt the finish, and should take the marker off!
Old Mar 9, 2002 | 11:11 AM
Psicho54's Avatar
Mineral spirits? Could you be more specific? Thanks.
Old Mar 9, 2002 | 11:38 AM
Flyin Wedge's Avatar
That's the exact name of the product,go to a hardware/paint store and ask for it.They won't look at you like you're crazy.
Old Mar 9, 2002 | 11:39 AM
bayarea408's Avatar
Psicho54,
sorry to hear about your mishap, was your car parked outside?
i am not sure what you can use to take the ink out, but whatever you use, make sure you try it out in a small area first.. and make sure that the thing isnt that abbrasive which might take the paint off the car
Psicho54's Avatar
Can I get this stuff at Home Depot?
Old Mar 9, 2002 | 11:45 AM
ScienceofSpeed's Avatar
Former Sponsor
Yes. It's also known as "paint thinner". Do not confuse this with "laquer thinner" which will damage your paint.
It is also sold at auto parts stores.
-- Chris
Old Mar 9, 2002 | 11:59 AM
Psicho54's Avatar
Well that was a quick fix ... the "mineral spirits" worked like a charm. Came right off with a bit of rubbing.
Once again, you guys ROCK.
Old Mar 9, 2002 | 01:53 PM
4IGS2000's Avatar
Spammer
I would try mineral spirits. It will not hurt the finish, and should take the marker off![
WD40
OIL based!!!
takes off anything, EXCLUDING THE PAINT!
Old Mar 9, 2002 | 02:25 PM
WD-40 works great on cleaning the counter sunk area around the lug nuts,spray it on a Q-Tip.
