first mod when FI is in the future?
Old Jun 19, 2006 | 07:26 PM
ChefJ's Avatar
Default first mod when FI is in the future?
I plan on purchasing and installing the comptech supercharger before the summer is over. I have a bone stock 2001 s2k with 25,000 miles on it. My question is what would be the first things to change considering a supercharger is in the future. I don't want to buy things that are going to be replaced when the supercharger is installed ie. CAI. Would putting headers and a catback be a good idea or should I just immediately swap out the differential because I know thats gonna go quick with all of that hp. Thanks in advance.
Old Jun 19, 2006 | 07:29 PM
Cyntex's Avatar
Short Shifter/Sways/Anything with suspension.
Old Jun 19, 2006 | 07:30 PM
darkfx's Avatar
catback, header, and 4.57 gears
Old Jun 19, 2006 | 07:32 PM
kane.s2k's Avatar
What are you going to swap the differential with? The comptech reinforced diff isn't worth the money IMO.
Old Jun 19, 2006 | 07:50 PM
SIIK2NR's Avatar
Headers
Exhaust
Test Pipe
Clutch upgrade
these all will compliment the SC
Old Jun 19, 2006 | 07:54 PM
ChefJ's Avatar
I don't know. I have heard that the differential is the weakest link in the s2000 when you start adding horse power.
Old Jun 19, 2006 | 07:58 PM
XclusiveAutosports's Avatar
Originally Posted by SIIK2NR,Jun 19 2006, 10:50 PM
Headers
Exhaust
Test Pipe
Clutch upgrade
This just about covers it all. You could also add gears to this list if you wanted to. About your comment for replacing the diff, do you plan on dropping the clutch at every street light? If not, then it should hold up fine with normal aggressive driving without dumping the clutch.
Old Jun 19, 2006 | 07:59 PM
kane.s2k's Avatar
Just hold off on the rear diff for now. There really isn't much of a problem with the factory diff unless you launch the car from a roll. There are guys with 400+whp still on the factory diff without any problems.
My suggestion for your first mod would be the clutch. The factory clutch isn't always upto the task for a supercharger. Then headers and exhaust.
Old Jun 19, 2006 | 08:21 PM
xviper's Avatar
What does this have anything to do with getting the car ready for a supercharger? These are things you would do for a NA S2000 and that's only if you don't like the level of handling the stock setup gives. If you haven't done this on a NA car, it's the last things you want or need in preparation for a F.I. car.
Old Jun 19, 2006 | 08:24 PM
xviper's Avatar
For the author of this thread,
You have a year 2001 car. For added insurance you might consider putting in the revised 4-hole oiljet bolts to improve under cylinder cooling and lubrication. This is not absolutely required but would give added peace of mind. I've been Vorteched (stock) for over 2 years and 20 something miles and the oiljet bolts were the first thing I did when the blower went on. I'm still on the stock clutch and am running the stock rear diff with 4.44s.
