First service - what does the dealer do?
Old Mar 22, 2005 | 05:51 AM
Cyclon36's Avatar
Default First service - what does the dealer do?
Ok, well the time has come for my first service/oil change on my car. I'm wondering if anybody knows exactly what the dealler is suppose to do during this. I don't want to pay alot of money for them to change my oil and "inspect" things when I can easily do that myself and not worry about something getting screwed up. I'm guessing the basic stuff is there like tire pressure and brake inspection, but is there anything that is more complicated? Thanks.
Old Mar 22, 2005 | 05:54 AM
mad-dog-one's Avatar
Extract your money!
Old Mar 22, 2005 | 07:11 AM
ruexp67's Avatar
They are there to separate you from your money. The first service is just an oil change.
You should consider a diff fluid change also. If you can do an oil change, you can do a diff fluid change. There are people that have done them as early as 4,000mi and seen all kinds of crud in there. I believe it's part of the break-in for the diff. I did mine at about 5,000 mi or so.
Old Mar 22, 2005 | 07:13 AM
tims2k's Avatar
oil change .. and tell you that the car needs a overhaul since its brand new
Old Mar 22, 2005 | 07:25 AM
klee1113's Avatar
nope, they would jsut change the oil and top of some fluids.. do it yourself if you have the time, its more fun that way
Old Mar 22, 2005 | 07:40 AM
Cyclon36's Avatar
Thanks guys. Definitely NOT going to the dealer now. I'm always skeptical about their work and try to do as much myself as possible. I'm actually going to take it to a local sponsor b/c I'm getting some other things done while I'm at it.
High temp brake fluid
Rear diff fluid
oil/filter change
Replace 05 clutch slave with my03
Thanks for the advice.
Old Mar 22, 2005 | 07:57 AM
JawKnee's Avatar
Let me know how that goes.
Old Mar 22, 2005 | 08:13 AM
Nate03's Avatar
Rear diff fluid
oil/filter change
yeah DIY...definitely nice to bond with your S
re the 04/05 slave mod - I'm now running an 04 slave with the delay valve removed...save yourself the 55/60 bucks purchase price of the 03 slave.
billman250 did a write up in under the hood - search of slave cylinder should find it.
Old Mar 22, 2005 | 08:16 AM
Cyclon36's Avatar
I pulled the 03 slave cylinder I had on my last S (MY04) so I'm set with that. Definitely a great change. You definitely don't want to launch it without one or take it to a track day.
S2K-Phil
Aug 11, 2011 09:15 PM
meri_gadi
Mar 11, 2010 02:34 PM
twofast4u
Oct 5, 2005 11:13 AM
jarod
May 15, 2005 03:27 AM
lvs2k
Mar 6, 2001 05:34 PM
