Foam air filters...
Old Feb 26, 2005 | 11:45 AM
Fumanchu's Avatar
I searched around for a thread like this...
I just came from a '94 RX7 and in the community the worst intake to use is with a foam filter. The extra heat found in a FD engine bay cooks the foam filters and makes them really brittle. Sooner or later pieces of foam will break off and suck them into the engine. Just wondering if it is an issue in s2k's?
**edit** Due to the job I have, I need to buy a CARB legal intake so I am either limited to the Comptech or the AEM. I am leaning towards the Comptech and I can just find a replacement filter for it.
Old Feb 26, 2005 | 12:06 PM
carloS2000's Avatar
good luck getting comptech to respond to anything other than your credit card order
Old Feb 26, 2005 | 12:15 PM
S2kracka's Avatar
I believe one of the K&N FIPK kits is CARB-approved.
Old Feb 26, 2005 | 04:56 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Try the JR filters.
Less restriction,and better filtration than K&N". (+2or3 HP)
Old Feb 26, 2005 | 07:28 PM
topcat7111's Avatar
As long as you use the right oil, you should be fine. It's the oil that traps the little micron of dirt. Service the filter every other oil change, just so the oil on the filter doesn't dry out.
Kashif92
Aug 13, 2013 10:13 AM
05slvrS2k
Feb 6, 2008 04:53 AM
blackfx35
Mar 30, 2006 04:34 PM
PAKS2K
Sep 27, 2005 12:57 PM
Driv300mph
Aug 17, 2004 07:24 PM
