Front grille keeps popping loose
Old Apr 14, 2009 | 04:50 PM
dparm's Avatar
Default Front grille keeps popping loose
The black plastic grille in the bumper opening seems to pop loose on the bottom really easily. Pretty much any time I drive it it comes out. The top stays anchored.
What do I need to order to hold that thing in place? I can't really tell. It's annoying as shit.
Old Apr 14, 2009 | 05:04 PM
ebchu's Avatar
fyi, that picture looks like an ap1 bumper
Old Apr 14, 2009 | 05:18 PM
dparm's Avatar
I know, the diagrams only show AP1 for some reason.
Old Apr 14, 2009 | 05:33 PM
nte11igence's Avatar
I'm having the same problem with my AP2. some of the tabs that hold hte bottom in place have either broken off or come loose. This would be a great resource for fixing the problem.
Old Apr 14, 2009 | 07:12 PM
hondaBeater's Avatar
hey OP,
the top is clipped on with tabs that allow the bottom to swing a little.
The bottom edge is 2 sided tape ( grille to bumper).
I removed my plastic grill for cleaning and put it back in. Replaced tape with white two sided foam tape. Works great. No prob with it for 1 year.
I just checked and mine is still on very tight.
BTW AP2 here.
Old Apr 14, 2009 | 07:19 PM
JeremyStone's Avatar
Be careful you don't break the pins that hold the grill on at the top. Mine was loose at the bottom and I procrastinated on fixing it, now all the pins except one on the top are broken.
I bought some epoxy, and am going to try to glue it back in.
Old Apr 15, 2009 | 05:38 AM
dparm's Avatar
Christ, they just tape it?! Man is that weak.
Old Apr 15, 2009 | 07:05 AM
Tabs and tape, so no rattle. Works just fine. Cuts weight down a bit too.
It's a light piece of plastic, screws would be dumb.
It is not JUST tape, more like mounting strips.
Old Apr 15, 2009 | 07:58 AM
centralcoastbuc's Avatar
I installed a couple of self tapping screws in from the bottom to help. The tabs didn't hold it tight and also some were broken.
Old Apr 17, 2009 | 06:09 PM
dparm's Avatar
I just tried some of that thick double-sided tape (it's almost spongy) and that's not working.
