gas saving tips?
Old Jun 27, 2008 | 08:03 PM
  #51
jamesk's Avatar
asian people=big oil company execs.
baby jalapeno poppers=american consumers
Old Jun 27, 2008 | 08:34 PM
  #52
R3DS2K's Avatar
Originally Posted by Elistan,Jun 25 2008, 04:22 PM
Not true about the acceleration thing - small throttle openings present a huge airflow restriction, making the engine work much harder than it would otherwise just to draw in air.
You're right about the slowing down part, though - using the brakes turns a portion of your kinetic energy into heat, and you need to combust more gas to get back up to speed. On the other hand if you can maintain a constant velocity, your only fuel expenditure is to overcome the normal frictions of everyday driving which you have to contend with anyway, rather than worry about overcoming your car's inertia. (That's why traveling at 70mph on the Interstate uses much less gas per mile than driving in the city with all its traffic lights and such.)
so your telling me that if i go WOT the pcm/ecm wont dump in more gas .. small throttle openings restricts air- true. less air also means less fuel..
Old Jun 28, 2008 | 05:32 AM
  #53
midnightmethane's Avatar
here is what i did this week to help my gas consumption but looks as well hehe:
removed the cat and replaced with a testpipe
removed spare tire
removed back of trunk liner (the entire piece covering the spare and gas fillr tube)
removed oem rear strutbar and replaced it with a cusco one
a good estimate of the weight saved i'd say: 50 - 65 lbs
Old Jun 28, 2008 | 06:33 AM
  #54
Ks320's Avatar
I guess there is an optimal point ... oh wellz ... just drive the car normally and don't abuse it, I'm sure the fuel economy is fine
Old Jun 28, 2008 | 06:44 AM
  #55
EP Heart's Avatar
Originally Posted by roflitzjinno,Jun 25 2008, 06:42 PM
took the bus all through out highschool. so no thanks :] but i like the offer.
thought about a fit but all i wouldve done was swap a k motor. so no thanks.
3.5k is what ive been shifting at lately. well see how that works out. i know im getting what i should be getting for city but id like to see what i can really get. large throttle openings? what does that mean?
and i havent even hit vtec so yeah... im good on that.
OP, I take it that you're keeping it out of VTEC for your break-in period?
Well, that's the same as me. However, I got almost 26 MPG on my last (and only ) fill-up. It was top-down about 95% of the time and the other 5% of the time, the A/C was on. I cruise at around 75 MPH on the highway. I also give it gas to rev-match or heel-toe on downshift. I'm not heavy on the throttle nor am I overly light on it, either.
I would also say that about 80% of that fill-up was on the highway. So, I'm not sure what our difference is, except maybe that I have more highway miles, different driving habits, or that only 1 fill-up doesn't give an entirely accurate estimate.
Old Jun 28, 2008 | 09:58 AM
  #56
R3DS2K's Avatar
removed spare tire
weight reductions only good for stop and go driving.. if you highway most of the time.. weight doesnt really matter that much..
also you can remove your pass. seat
Old Jun 28, 2008 | 10:35 AM
  #57
alSpeed2k's Avatar
Some good tips!
Do you really use less gas when the car is in gear and coasting vs being in Neutral and coasting? The former is definitely safer! What about when you are stopped at a light in gear or in neutral? Does it make a difference?
Old Jun 28, 2008 | 12:13 PM
  #58
Honder's Avatar
Originally Posted by GT_NFR,Jun 25 2008, 03:36 PM
Driving the car in too tall of a gear won't save gas....if you're out of the power band you're not making efficient use of the engine thus reducing your gas mileage.
I beg to differ. Each time a cylinder is charged with mixture, is ignited and produces a power stoke, there is fuel used. The fewer times that happens in a given distance (a mile), the fewer gallons of fuel are used thus returning higher fuel mileage.
The engine may not be at its peak power level, but peak power equals peak fuel usage. A fuel dragster uses several gallons of fuel in a quarter mile. They are at their absolute peak power the entire time.
Old Jun 28, 2008 | 12:29 PM
  #59
R3DS2K's Avatar
Originally Posted by alSpeed2k,Jun 28 2008, 10:35 AM
Some good tips!
im in gear when im slowing down.. but i downshift if its for a turn. and i dont stop 100%
at a light.. im in N .. it doesnt make a difference but why hold the clutch down lol
Old Jun 28, 2008 | 08:16 PM
  #60
G's Avatar
G
https://www.s2ki.com/forums/index.php?act=S...0#entry13736168
