Gauge Difference between years
Old Feb 17, 2007 | 12:51 PM
STOK's Avatar
Default Gauge Difference between years
I have seen a few different looking gauge clusters, some with 1/2 circle fuel and temp gauges and some with flat, straight fuel and temp gauges.
Which years are which.
Thank you, and if thier is a better way to find information on this subject, please let me know, i am totally new here.
Old Feb 17, 2007 | 12:53 PM
itsmylittlebrothersbike's Avatar
AP1 is straight. The arc shaped temp and fuel are AP2.
Old Feb 17, 2007 | 12:55 PM
STOK's Avatar
So, 2003 and below are straight and 04 and above are curved???
Old Feb 17, 2007 | 01:03 PM
j03chu's Avatar
ap1 (2000~2003) the rpm stretches from one end to the other 1k rpms to 9k rpms respectively. the oil temerature + fuel gauges are straight lines.
ap2 (2004~2007) the rpm stretches from left to about 3/4th mark from 1k rpms to 8k rpms respectively. the oil temperature + fuel gauges are semi circle arches. ap2's also have a clock in the tach, and the 2006+ s2000's have a outside temperature gauge + clock in the gauges as well.
ask away if you still have questions.
Old Feb 17, 2007 | 01:07 PM
STOK's Avatar
Cool, thanks man, i was actually looking at getting an 06/07, so its good to know that they have a temp and a clock.
Awesome, thanks for the help.
Old Feb 17, 2007 | 05:40 PM
vtec9's Avatar
for some reason the tachometer in the 2004-2007 S2000s stop at 8,000. I'm still trying to figure out where the last 1,000 rpms went.
Old Feb 17, 2007 | 06:20 PM
joes sled 2000's Avatar
[QUOTE=vtec9,Feb 17 2007, 10:40 PM]for some reason the tachometer in the 2004-2007 S2000s stop at 8,000.
Old Feb 17, 2007 | 07:11 PM
MyEeek's Avatar
Here is another note about the ap1's cluster gauges:
02-03 - looks exactly like the 00-01's as well, however, there is a line between the RPM numbers and RPM marks. The 00-01 does not have this and imo, looks better without it.
Other than that, it is the same.
Old Feb 17, 2007 | 07:16 PM
MyEeek's Avatar
Take a look at an 00/01 gauge:
Now, the 02/03 has that extra line as you can see:
Old Feb 18, 2007 | 08:33 AM
HiPER's Avatar
correct. also, the colors are a little different as well. 00-01 odometer has a yellowish hue while the 02-03 have a reddish hue.
