Gearing question
Old Dec 28, 2000 | 02:03 PM
s2Kiefer's Avatar
Hello - Question . . . How can you figure out how fast a car can go per gear, per RPM? Would you use gear ratios? Final drive? Wheel size? I've been confounded by this question for months, and nobody can seem to give me a straight answer . . .The only way I've have found to calculate this is from actually driving the car . . . Would anybody like to clue me in? (ex. how fast would do you travel at 6000RPM in 4th gear)
Old Dec 28, 2000 | 02:06 PM
cdelena's Avatar
Rather than fool with the math here is the speed in gears mph/1000 rpm. Now you can just multiply..
4.8
7.3
10.1
12.9
15.5
18.5
Old Dec 28, 2000 | 03:28 PM
s2Kiefer's Avatar
cdelena -
Thanks for the numbers . . . . Would it be too much to post the math? I would really appreciate it. I sure others would as well . .
-Jason
Old Dec 28, 2000 | 03:36 PM
2kturkey's Avatar
[QUOTE]Originally posted by cdelena:
[B]Rather than fool with the math here is the speed in gears
Old Dec 28, 2000 | 03:55 PM
s2Kiefer's Avatar
2kturkey - Ha Ha. I meant the math to get the 12.9 . . . the gear ratio for the S2K in 4th is 1.161, and the final drive is 4.1:1, and the wheel size is 16" (minus tire size) . . .can you somehow get 12.9 from this?
Old Dec 28, 2000 | 04:09 PM
cdelena's Avatar
It is extremely challenging to make a transmission that shifts well at 9000 rpm, so one of the unusual things is the S2000 transmission is a secondary reduction shaft.
You are missing the 1.160 output reduction. Do one more multiplication and I bet your math will come out.
Old Dec 28, 2000 | 09:30 PM
S2WOOOW's Avatar
This chart may come in handy
Old Dec 28, 2000 | 09:38 PM
YoungS2K's Avatar
S2WOOOW:
NICE chart. very helpful.
Old Dec 28, 2000 | 10:55 PM
RT's Avatar
RT
[QUOTE]Originally posted by s2Kiefer:
[B]2kturkey - Ha Ha.
Old Dec 28, 2000 | 11:18 PM
cthree's Avatar
Administrator
Originally posted by RT:
You ready for this?
9000 Rev/min x 1/1.161 x 1/1.160 x 1/4.1 x 1/837 Rev/mile x 60 min/hr = 116.84 mph for 9000 rpm in 4th gear.
To get the 12.9, take the 116.84/9 = 12.98@1K rpm.
This number differs from the target by about 1/2% (assuming all given ratios were correct) either due to rounding error or a wrong assumption that the stock Bridgestones roll 837 times in one mile. (If we used 842.3349 rev/mile it would come out dead nuts).
Interesting except I've done 122mph in 4th at redline. Is my speedo off? I know it was 122 because that's what it said when the redline light flashed and I shifted to 5th. So either I had a tailwind, the speedo is wrong or the math is wrong.
