Which gears should i get?
Old Oct 9, 2005 | 08:22 AM
CarBoN's Avatar
Default Which gears should i get?
goin in a 2002 with a na setup
aem cold air
j's racing 70rr header
j's racing 70rr single exhaust
test pipe
hondatat intake manifold gasket
mugen headgasket
mugen baffeld oil pan
cusco oil catch can
mugen thermostat
mugen oil cap
mugen rad cap
mugen magnetic drain plugs
koyo radiator
j's racing radiator cooling plate
oil cooler
Aem Ems
exedy single disc clutch kit
now i need to know which gears i should get, which ones will work best with my setup
which ones will give me what effect
thanks alot for any and all help
Old Oct 9, 2005 | 01:55 PM
steven975's Avatar
4.56 gears are the best all around and are stronger.
If you do no freeway driving AND want max acceleration, get the 4.77:1 gears.
Old Oct 9, 2005 | 02:13 PM
CarBoN's Avatar
how bad are the 4.77's on the highway, cant be any worse then my itr was, when i was at 80 i was at like 4500 rpms almost 5 grand, and it didnt bother me
with the 6th gear on the S it cant be any worse
i think im gonna go with the 4.77's for the best accelaration
btw about how much whould it be to install the gears, like whats the average amount of time it takes someone to install gears
if it matters the car will already be up on a lift getting the clutch installed
Old Oct 9, 2005 | 05:17 PM
trich1687's Avatar
Go with the 4.77s, Don't even ask about the cost of the install, ask about the quality . If the installer doesn't know diffs and has a lot of experience RUN! Jeff ( hardtopguy) can hook you up. I did the diff R&R myself and had a high end shop do the ring a pinion setup. They only charged me a few hrs labor. Do not skip on the installer or you will be sorry . The 4.77s will put a smile on your face! and don't worry if installed correct they will hold up to clutch dumps just fine , I do it often. No problems so far with 15k since the install , That's a hard 15k ...balls out . ENJOY
Old Oct 9, 2005 | 08:10 PM
CarBoN's Avatar
excellent info thanks alot, im going with the 4.77's
the way you guys talk, are the 4.77's not as strong as the 4.56's
im excited to drive this car, with the gears, the exedy clutch, and the j's 70rr header and j's 70rr exhaust, with a bunch of other stuff with a aem ems, its going to haul ass
im really exicted to move into my new house and get setteled and get a second car, im going to do the inlinepro 2.5ltr stroker kit, some head work, i was thinking maybe the toda head package
and finnally some twm 52mm individual throttle bodies
pinoyk20
Jan 15, 2008 06:36 PM
learnerspermit
Jun 18, 2004 07:21 PM
