Ground points in trunk?
Ok this is what you do. Avoid the gas tank!!!!!
Then find a weld point. Its a little indent circle in the metal. Take some sand paper scrape your self a nice circle down to metal(dremel tool is nice) Then throw a self tapping screw through there.
Better yet get your self a nice seat belt bolt. Those go right to the frame of the car. That is the best thing but in a pinch go for a weld spot. Somewhere inconspicuous. Oh you could also try the rear strut tower bar. That might be a good spot!
Then find a weld point. Its a little indent circle in the metal. Take some sand paper scrape your self a nice circle down to metal(dremel tool is nice) Then throw a self tapping screw through there. Better yet get your self a nice seat belt bolt. Those go right to the frame of the car. That is the best thing but in a pinch go for a weld spot. Somewhere inconspicuous. Oh you could also try the rear strut tower bar. That might be a good spot!
Pinky is right, look for a bolt somewhere if possible. I always take a volt meter and check around for a good ground. I haven't torn into the trunk of my S2000 yet, but I'm yet to find a Honda that doesn't have a bolt somewhere in the back suitable for a ground.
No wonder why they call you the stereo guru!
