Had my first experience with the...
Old May 4, 2001 | 10:10 AM
TrojanHorse's Avatar
ass stepping out on me. Just got back from giving a co-worker a ride and there is a long straightaway right before our work that we always race on. I hold the current record with 117 mph on the straight so I decided to take a crack at the record. The entrance to the straight is a tight right hander that you can take in 2nd gear. Well, to go for the record I figured I'd try to carry that corner faster than usual. As I was coming out of the corner I was in the gas a little too hot and the ass stepped out on me. I lifted and pulled it back in. Little bit spooky. Lesson learned, no harm, no foul.
Old May 4, 2001 | 10:45 AM
Wesmaster's Avatar
You will learn that this is a feature of the car, not a drawback - use it.
Wesmaster
Old May 4, 2001 | 11:44 AM
erik's Avatar
I have a question about if the back end starts to slide, I thought you were supposed to give a RWD car a little more gas and turn toward the slide to get the car to recover. I thought letting off the gas could put you into a worse situation then you already are in.
Am I mistaken?
ERIK
Old May 4, 2001 | 11:53 AM
Wesmaster's Avatar
[QUOTE]Originally posted by erik
[B]I have a question about if the back end starts to slide, I thought you were supposed to give a RWD car a little more gas and turn toward the slide to get the car to recover.
Old May 4, 2001 | 12:12 PM
Penforhire's Avatar
...also known as lifting
Old May 4, 2001 | 12:19 PM
Allan Haggai's Avatar
Don't Lift!
Old May 4, 2001 | 12:23 PM
William's Avatar
Think you mean drifting.
Old May 4, 2001 | 02:55 PM
Dallas's Avatar
Wesmaster
From what I understand, you are absolutely right. It seems to be generally held that understeer is "safer" for those without performance driving experience, which is probably why most cars understeer. The oversteer of the s2k seems to be the preference of the more "serious" drivers.
Old May 4, 2001 | 04:24 PM
malachi's Avatar
*controllable* and *predictable* oversteer is, indeed, the choice of experienced drivers.
check out the video of Stefan Roser driving the 'ring for an example of perfectly controlled oversteer.
Old May 4, 2001 | 05:23 PM
wirejock's Avatar
I call it drift. Just hold the throttle or back off just a tiny bit, tuck in your sphincter and control the drift. She'll recover. Much more preferrable to understeer.
