Handbrake Issue
Old May 4, 2022 | 08:24 PM
tcalo's Avatar
Default Handbrake Issue
The handbrake in my car needs to be almost fully engaged for it to hold. I went to adjust it and found that I have to almost fully tighten it for it to hold after a few clicks of engagement. The issue is that when it is disengaged, it rubs against my wheel slowing it down. I also found this was happening even with the handbrake nut fully loose. Basically, it didn't matter how I adjusted the handbrake, when it was disengaged either the rotor or the pad was rubbing which was dragging the wheel to a stop. Has anyone had any experience with this or know the best solution to stop the dragging? Thank you!
Old May 5, 2022 | 09:29 AM
Scigheras's Avatar
Disconnect the handbrake from the brake caliper. If it still drags you need a refurbished caliper.
Old May 5, 2022 | 11:16 AM
B serious's Avatar
You likely need a caliper. Check.
Or your cable is massively stretched. Check.
Old May 5, 2022 | 05:20 PM
noodels's Avatar
Would slacken cable, adjust calipers pistons,and asses how much cable needs adjustment.Retry .
Z32MadMan
Dec 9, 2018 08:15 AM
Breaking Point
May 4, 2012 03:25 AM
toniotran
Jan 19, 2009 04:54 AM
toby2000
Nov 30, 2008 08:37 AM
KSs2000
Apr 6, 2004 05:36 PM
